Re: Camshaft ID help
[Re: 74_duster]
#2228713
01/06/17 05:00 PM
01/06/17 05:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think thats a Crane cam... I was trying to look up some numbers from the lobe profile catalog but I think thats a old cam... I assume its a hyd flat tappet
[Re: 74_duster]
#2228862
01/06/17 08:37 PM
01/06/17 08:37 PM
MR_P_BODY
those numbers were valve lift and it is a hyd flat tappet.
When you take off the valve covers and find all the left and right hand rockers on the wrong sides i figured it was time to tear it down and do it right. That would put some fear in ya You might try calling Crane and see if those numbers are theirs... or they MIGHT know who
[Re: cknight]
#2230884
01/09/17 04:24 PM
01/09/17 04:24 PM
Posts: 28 MI
74_duster
MI
This is a Crane part number 969361. It's the BluePrinted (computer-smoothed) equivalent of the factory 2899206 hydraulic lifter camshaft that was original equipment in the 275HP 340 cu.in. 4bbl engines. Cam lobe lift is .2861" intake, .2958" exhaust. Gross valve lift with the standard 1.5:1 rockers is .429" intake, .444" exhaust. Lobe separation is 114 degrees. The duration at .050" tappet lift is 210 degrees intake, 221 degrees exhaust. Cam timing at .050" is: intake opens 8 ATDC, intake closes 38 ABDC, exhaust opens 45.5 BBDC, exhaust closes 4.5 BTDC. This particular cam was produced the 4th week of 1987. Regards, Chase cant get a better answer than that. Thanks for the help Chase
