Re: New Cast Iron vs Aluminum heads
[Re: MoparDan]
#2230636
01/09/17 04:43 AM
01/09/17 04:43 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
With the continuing deterioration of pump fuel why take a chance with iron heads No way will I build a iron headed motor with more than 9.5 to1 compression ratio, even with a big cam Go with new aluminum heads now
[Re: MoparDan]
#2230684
01/09/17 10:51 AM
01/09/17 10:51 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
What vehicle and compressor style? Lots of Dakotas out there with factory EFI, AC, and Edelbrock RPM heads.
I like aluminum for lots of reasons, higher compression capability, faster cooling/no boil over after shutdown, weight savings. If building a correct restoration, then sacrifices in performance must be made. Manifolds vs headers, low dual plane intake, etc. if building a race engine, other than the FAST class, who cares if it's not factory looking?
**Photobucket sucks**
[Re: Bull1tt]
#2230699
01/09/17 11:50 AM
01/09/17 11:50 AM
RapidRobert
Does the exhaust system need to be upgraded to gain some of the performance increase you are after? If you are in the 10:1 range I would think that you are real close to the ping limit on pump gas right now & in fact I think an actual 10:1 would be talking. If you know your dimentions/specs you could see what you have now & what you will after a swap. The United Machine calculator is handy (Google it). Just me I would go aluminum and I would think any AC fitment issues could be easily fabbed & taken care of. there was just a good thread on perf bennie of alum VS iron. was not real positive. Not really my area but I would think if the alum wicking away heat faster would quell the pinging from the increased CR that you would be gain performance. ??? any thoughts on any other area of your build that might be holding you back? what I would do before anything is bring your curve in faster & experiment in that area.
[Re: MoparDan]
#2230701
01/09/17 11:52 AM
01/09/17 11:52 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Aluminum all day long. Talk to Sasquatch!
[Re: MoparDan]
#2231936
01/10/17 11:11 PM
01/10/17 11:11 PM
Posts: 132 Kingman, Az
Scojodak
Kingman, Az
Yes, aluminum heads would be beneficial, but if he holds .035/.040 quench with flat top pistons, 10:1 CR shouldn't be a problem with iron heads.
Dakota for life!
[Re: dogdays]
#2232640
01/12/17 01:29 AM
01/12/17 01:29 AM
Posts: 20,637 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
A good read. http://www.enginebasics.com/Advanced%20Engine%20Tuning/Static%20vs%20Dynamic.htmlYou can flirt with to 10.1 with iron heads in some cases. My brother has done it with a SB Olds 350 with iron heads that have had the heat risers filled and the valve faces and combustion chambers ceramic coated all in an effort to eliminate hot spots. Camshaft timing, combustion chamber design, bore diameter, altitude above sea level, etc. also factor in as well. If in doubt it's better to error on the safe side.
