440 hp2 block ID pad oddity?
#2229788
01/07/17 10:17 PM
01/07/17 10:17 PM
Posts: 1,609 Lapeer, MI.
todd440
Lapeer, MI.
Ever see this? Casting date is 5-28-68, vin stamped XS29L9B195682, so slated for 1969, which I'd expect to see "E440" on the pad. The only one close to this WT, which is water test. Sooooo, ENIGINE TEST?? Stamping is ET41 then a maltese cross.
Re: 440 hp2 block ID pad oddity?
[Re: todd440]
#2229842
01/08/17 12:01 AM
01/08/17 12:01 AM
Posts: 17,565 Las Vegas, NV
6bblgt
Las Vegas, NV
What is the block's casting number? can you post a picture of the VIN stamping? IIRC "T" was an indicator for "Truck" before the '70s usage for "TRENTON" possible, but 7/24 is 3 months+ before the Charger R/T would've been assembled '69 vs. '79 440s - what's the purpose of the relief along side of the pad? I don't think I've seen that on any '60s 440s there's also a Maltese Cross hiding in there, was the crank undersize?
[Re: todd440]
#2229910
01/08/17 09:38 AM
01/08/17 09:38 AM
todd440
Lapeer, MI.
It's the right early casting number. It's not a later "Trenton" block where you'd normally see 4t440 or 5t440 on the pad. As far as that milled "locator" spot next to the pad, it's on early blocks also, but not all. I've got a 1970 S440 warranty block that has it also. I've always assumed it was a locator or register for tooling. Vin has a funny "9". As far as the different font in the 4's, I'd sorta expect that, seeing it was cast one place, assembled elsewhere, assigned to a certain car in yet another location..and so on.
[Re: todd440]
#2230929
01/09/17 04:52 PM
01/09/17 04:52 PM
Posts: 75,418 A gulag near you.
JohnRR
A gulag near you.
That would be the case if the info on the top pad is stamped at different times during the machining and assembly process ??? It has nothing to do with casting and assignment to the vehicle which is done at the auto assembly plant , engines were not built at the auto assembly plants ???
Mainstream Media is the new Pravda
[Re: JohnRR]
#2231002
01/09/17 06:02 PM
01/09/17 06:02 PM
todd440
Lapeer, MI.
That would be the case if the info on the top pad is stamped at different times during the machining and assembly process ??? It has nothing to do with casting and assignment to the vehicle which is done at the auto assembly plant , engines were not built at the auto assembly plants ??? I should have worded it differently. Some numbers were stamped at the engine plant, more that likely others were stamped at the cars assembly plant. Blocks were stored for months some times. Not everything was done the same day, at one place, and there wasn't just one set of "master" stamps. Question still remains..any ideas on the ET41? It hasn't been milled off and restamped. I'm not claiming it's rare and valuable...nothing like that. I just haven't seen it before. It came with my 69 GTX, so I'm going to build it.
[Re: todd440]
#2231108
01/09/17 08:34 PM
01/09/17 08:34 PM
Posts: 1,793 Big Sky Country
MO_PA
Big Sky Country
The 41 is 413 the A means .020 oversize cylinder bores. If I remember right the early max wedge blocks were stamped HP but this wouldn't be max wedge
[Re: todd440]
#2231135
01/09/17 09:27 PM
01/09/17 09:27 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My 64 413 in my 64 300 was stamped HP. The maxies were stamped MP (maximum performance) with the high compression maxies getting an HC as well, IIRC.
[Re: todd440]
#2231426
01/10/17 03:31 AM
01/10/17 03:31 AM
6bblgt
Las Vegas, NV
The pic of the casting number is above, painted orange later the same day. It's 2536430, which is 440. Date is 5/29/68. Not a 413 block, different casting number, smaller bore.
understood, but the top stamp is NOT accurate for a '69 440 for any application
