Are all 71- 74 Ply B body doors the same?
#2228665
01/06/17 03:52 PM
01/06/17 03:52 PM
Posts: 658 Dillsburg, PA
Wizard
Dillsburg, PA
Will 74 Satellite doors fit and are the same as 71-72 doors? How about qtr panels?
Guns, God, and Country.
U.S. Veteran
Re: Are all 71- 74 Ply B body doors the same?
[Re: Wizard]
#2228765
01/06/17 05:59 PM
01/06/17 05:59 PM
Wizard
Dillsburg, PA
How about the frame rails? Would they all be the same for 71 thru 74? How about trunk floor and whole front and rear floor boards? Inner fenders?
U.S. Veteran
[Re: Wizard]
#2228798
01/06/17 07:08 PM
01/06/17 07:08 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Inner fenders are 71-2 only 73-4 has completely different inner fenders even from small block to big block on the passenger side. Trunk floor is the same 71-3, 74 is it's own raised trunk floor. Front frame rails are 71-2 only as the 73-4 front rails are different and has a completely different suspension where the upper control arms mount to the k-member not the frame rails. The front floors and rear floors can be used. I believe the rear rails are the same. Keeping in mind while some of these parts will fit there are some differences in appearances and body plug sizes in the panels but they fit.
[Re: Wizard]
#2228929
01/06/17 10:26 PM
01/06/17 10:26 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Also 4-dr trunk pan is about 1" longer than 2-dr. 71-4 rear frames are the same for both 2 and 4 door. I have found 3 different 72 front floor pans. Just minor differences and all will fit both 2 and 4 door.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
