Page 5 of 5 1 2 3 4 5
Re: The Direct Connection Test Car [Re: ZIPPY] #655854
04/12/10 01:55 PM
04/12/10 01:55 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
After a bunch of internal discussion and some debating, we are going with a crank driven mechanical fuel pump from Aeromotive along with their regulator/filter.
We're not sure if we really need this much fuel pump, but better too much than not enough.
Our in-house fabricating genius is going to make some new fuel rails from the extrusions you see poking out of the box. Not because he wants to, but because nothing is going to fit anymore. We have the MP billet fuel rails on it currently which are fine for a regular 392... but they won't work with the 120lb injectors (!) and -12 line we're going to use so they gotta go. The injectors look like a miniature fire hose nozzle....
Re: The Direct Connection Test Car [Re: AndyF] #655855
04/12/10 02:01 PM
04/12/10 02:01 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Looks like an aftermarket casting. Is that an ATI powerglide with a G3 front bell?
Yep that's what it is. SFI-everything, and everything from ATI. ATI's flexplate is a real nice looking piece also, but I didn't get any pics of it (maybe next time).
We're probably going to have to take a shot in the dark with the coverter. There is no dyno information at this time, only an internal thought (hope?) of what it might make power wise. It'll probably be run the old fashioned way and then dynoed much, much later (if at all).
That is, if we don't bring the engine back home in a bucket.
Re: The Direct Connection Test Car [Re: ZIPPY] #655856
04/12/10 02:04 PM
04/12/10 02:04 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Great stuff!
Re: The Direct Connection Test Car [Re: ZIPPY] #655857
04/12/10 04:26 PM
04/12/10 04:26 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
this is very cool stuff
Re: The Direct Connection Test Car [Re: 1Fast340] #655858
04/12/10 05:06 PM
04/12/10 05:06 PM
Locomotion Offline
Locomotion  Offline
Unless I missed it , are you staying with 9" tires or going bigger, if there is room?
Re: The Direct Connection Test Car [Re: ZIPPY] #655859
04/12/10 09:39 PM
04/12/10 09:39 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Going to keep the cell in the trunk?...only 120lb injectors....don't plan on making as much power as I thought! ...
really going to run #12 to the rails....way, way overkill.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: The Direct Connection Test Car [Re: ZIPPY] #655860
04/12/10 10:16 PM
04/12/10 10:16 PM
Here.
Ranger50 Offline
Ranger50  Offline
Here.
That setup just doesn't seem to make sense to me. I have personally ran -10 line with a Weldon 2025 to 1/2" rails and 83# injectors up at 600rwhp and have seen even more power, ~1000rwhp, from the same setups. With 70# of FP, you aren't going to lack any flow problems until you run out of volume.
One other question, why not cheap-o 160# injectors??
Brian
Re: The Direct Connection Test Car [Re: Ranger50] #655861
04/13/10 07:50 PM
04/13/10 07:50 PM
Center Line, MI
Mopar#1 Offline
Mopar#1  Offline
Center Line, MI
Zippy meant -12 to the pump, -10 to the Y, -8 to the rails.
Re: The Direct Connection Test Car [Re: Mopar#1] #655862
04/13/10 08:23 PM
04/13/10 08:23 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Yep, sorry about that...my statement didn't make any sense to me either after I re-read it a few times!
As Mopar #1 stated it's -12 to the pump, and then after that it steps down to smaller lines. The smaller line will fit the rail without a problem but the bigger injectors sure won't, and I messed up that particular detail. Trying to talk on the phone and type at the same time doesn't work too well....
Myron I think we will be looking at different rear tires, radial stocker slicks really weren't designed to work with a car like this.... There is a little bit of room left on the inside but not much...it might or might not be practical to use that space up but maybe not, depending on wheel selection etc. Haven't researched it yet but should probably start.
I'm going to be doing more wrench work on it over the coming weeks (which really means I'll be slacking off on pics). There probably won't be another update for awhile but if anyone has any comments or questions, feel free to chime in.
Re: The Direct Connection Test Car [Re: ZIPPY] #655863
04/14/10 08:08 AM
04/14/10 08:08 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
Looking good Zippy!
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: The Direct Connection Test Car [Re: ZIPPY] #2228603
01/06/17 02:24 PM
01/06/17 02:24 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Someone brought this up today and I had to go look and see if the thread was still there. Glad it still exists.
This is, of course, all ancient history now (and I'm also two jobs past this, still an automotive guy but not there anymore....and no longer have any idea what the heck anyone there is doing...or not doing...whole other topic) but man, I am really glad I was there and did everything that I could, when I had the opportunity.
Back to your regularly scheduled discussion.
Rich H.
Esse Quam Videri
Re: The Direct Connection Test Car [Re: ZIPPY] #2228620
01/06/17 02:49 PM
01/06/17 02:49 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
grin
Re: The Direct Connection Test Car [Re: ZIPPY] #2228721
01/06/17 05:13 PM
01/06/17 05:13 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Was/is there some other thread with the results?
This one just seemed to fizzle out before any details were revealed.
Re: The Direct Connection Test Car [Re: fast68plymouth] #2228802
01/06/17 07:10 PM
01/06/17 07:10 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
It sure did fizzle out...there was a loss of interest all the way around. I may have mentioned the results somewhere else, can't recall.
ET was 9.24 in testing, I can't recall mph but it was a bigger number I definitely couldn't relate to comparing to my slow-ass street/strip personal experience. I'm sure my partner and/or engineering lead could remember MPH if asked.
I've attempted a bunch of times to document projects and results here over the decades(!), and it usually doesn't work out...this is usually what happens....
Rich H.
Esse Quam Videri
Re: The Direct Connection Test Car [Re: ZIPPY] #2229027
01/07/17 12:17 AM
01/07/17 12:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
twas an exciting time....
