340 Crank.
#2228346
01/06/17 01:08 AM
01/06/17 01:08 AM
Posts: 12,495 Western Colorado High Desert
moparmarks
In mid 72 the 340 got a cast crank, correct? What about 4-spd cars? Did they get a cast or forged crank? Late 72-73.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: 340 Crank.
[Re: moparmarks]
#2228436
01/06/17 03:47 AM
01/06/17 03:47 AM
Posts: 4,457 Washington
madscientist
Washington
Only 73's had cast cranks. All 72's should have been forged.
Re: 340 Crank.
[Re: moparmarks]
#2228445
01/06/17 04:37 AM
01/06/17 04:37 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
They went to the cast crank in Apr of '72... Only way to know for certain is to look at the damper on the engine...Cast crank has a different damper. http://www.hamtramck-historical.com/images/TSBs/1972/09-07-72C%20page1.jpg
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: 340 Crank.
[Re: moparmarks]
#2228598
01/06/17 02:18 PM
01/06/17 02:18 PM
Posts: 9,895 MI, usa
dvw
MI, usa
My 73 Challenger is a 4 speed, cast crank. Doug
Re: 340 Crank.
[Re: dvw]
#2228926
01/06/17 10:23 PM
01/06/17 10:23 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
This pic was floating around a while back... It shows the difference... ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I Think it says "for use with 340 cast crank only" stamped on the front...
...FAFO...
Re: 340 Crank.
[Re: moparmarks]
#2228963
01/06/17 11:11 PM
01/06/17 11:11 PM
moparmarks
Ok thanks. Have a friends 70 Cuda with a 340 that he took out of a 68 Barracuda but is a 71 casting and a 72 vin. It has a steel crank damper. Don't really know much about the motor but it has a really bad vibration. Seems to be RPM related. Have not pulled the pan but the crank is drilled for a pilot bushing.
Re: 340 Crank.
[Re: moparmarks]
#2229266
01/07/17 12:58 PM
01/07/17 12:58 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Ok thanks. Don't really know much about the motor but it has a really bad vibration. Seems to be RPM related. Before you go chasing problems, I purchased a vehicle from an owner who had an ASE shop/mechanic(s) tell him the engine that was swapped into his vehicle had damper/and or converter balance problems because the components had been combined between 2 motors by another shop,...I spent all of 5 minutes to discover that the plug wires on 2 cylinders were crossed over, sure felt like a vibration/RPM problem at the time, so eliminate the obvious before tearing into the motor Mike
Re: 340 Crank.
[Re: DAYCLONA]
#2229272
01/07/17 01:04 PM
01/07/17 01:04 PM
moparmarks
Ok thanks. Don't really know much about the motor but it has a really bad vibration. Seems to be RPM related. Before you go chasing problems, I purchased a vehicle from an owner who had an ASE shop/mechanic(s) tell him the engine that was swapped into his vehicle had damper/and or converter balance problems because the components had been combined between 2 motors by another shop,...I spent all of 5 minutes to discover that the plug wires on 2 cylinders were crossed over, sure felt like a vibration/RPM problem at the time, so eliminate the obvious before tearing into the motor Mike He has had this 340 in the car for a few years now and we have eliminated most everything else including the tranny.
Re: 340 Crank.
[Re: 340clone]
#2229274
01/07/17 01:07 PM
01/07/17 01:07 PM
moparmarks
I have a '72 model year 340 with a 9/30/71 casting date with a cast crank. Ok that helps. Thanks. He might have a cast crank with a forged balancer. As stated before 340 4-spd could have a cast crank. Looks like we need to pull the pan to be sure.
Re: 340 Crank.
[Re: moparmarks]
#2230044
01/08/17 02:57 PM
01/08/17 02:57 PM
Posts: 598 NC, USA
davenc
NC, USA
You may be able to use an inspection camera up through the oil drain plug. The cast crank looks fairly different. I think the only challenge might be keeping the camera lens clean for long enough to get a good look.
Correction: windage tray may block the view.
Re: 340 Crank.
[Re: Action Jackson]
#2233677
01/13/17 07:42 PM
01/13/17 07:42 PM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Keep in mind that the 340 had the smallest external weight of any Mopar. If both the balancer and converter/flywheel are correct, replacing the balancer by itself might not make a noticeable difference.
Re: 340 Crank.
[Re: moparmarks]
#2233695
01/13/17 08:16 PM
01/13/17 08:16 PM
Porter67
Or the other way around, ive a cheater motor I used a steel crank on and had it balanced with a cast balancer mentioned above that the cast 340s use so by looks it was a low performance 73 340 but it wasnt.
The 340 cast unit with its odd shape is semi hard to find I think.
Mine looked stock with a little bit of weight removed...
PM me if someone wants this crank and balancer, its got a bit more stroke the oem too.
Re: 340 Crank.
[Re: moparmarks]
#2233721
01/13/17 09:26 PM
01/13/17 09:26 PM
moparmarks
The motor has a forged crank balancer but don't know which crank it has. He is gone working for about a month so we'll see what he wants to do when he gets back. May need that cast balancer. Thanks
