Best way to remove layers of paint from pot metal? #2227435
01/04/17 11:01 PM
01/04/17 11:01 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Just bought a pair of quarter panel scoops for my 71 Challenger. chipped areas indicate they've been through at least 5 different pain jobs over the years. Aircraft Paint Stripper peeled up the very top coat and that was all.
Had bad luck with sand/bead blasters blistering pot metal.
What's the best way to clean up parts like this?
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2227494
01/05/17 12:06 AM
01/05/17 12:06 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Crushed walnut shells? I would think any type of media that does not create heat.
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2227499
01/05/17 12:14 AM
01/05/17 12:14 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've used "Super Clean" it's a purple cleaner/degreaser from walmart... cheap and softens/strips paint on metal easily. Just soak in the stuff for a while and rinse/wipe off.
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2227510
01/05/17 12:21 AM
01/05/17 12:21 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2227526
01/05/17 12:43 AM
01/05/17 12:43 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
"blistering" pot metal ... seriously ?! I blast pot metal often enough and have never had that happen. My guess is what you think are blisters is actually corrosion that's been blown away. Corrosion is very common on exterior pieces.
Unless paint is fresh, I've never seen a stripper that will take off 5 layers. Hell, most won't even touch epoxy primer! If you don't want to blast them, keep at it with the stripper. Or try a d/a sander.
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2227529
01/05/17 12:50 AM
01/05/17 12:50 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One application of stripper will not take off 5 layers of paint. Keep trying.
Don't be the exception.
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2227607
01/05/17 04:21 AM
01/05/17 04:21 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Apply the aircraft stripper again and put it in a heavy plastic bag & tie it shut.It will not evaporate this way and will soften more of the paint. Be patient,a few hours or overnite to set.Pull from bag,scrape with a plastic scraper,or carefully with a razor and repeat as necessary.You can go over it with paint stripper and a scotch brite pad to finish,then wash with water to neutralize.Fine blasting can clean and detail it for paint prep.
RT
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2227871
01/05/17 03:38 PM
01/05/17 03:38 PM
Chicago
PurpleBeeper Offline
Chicago
I agree with the stripper idea. The key ingredient in it you're looking for is "methylene chloride" aka "dichloromethane" which will strip even industrial epoxies, urethanes, acrylics..... all paints that I know of. It doesn't work fast (a few days maybe) & it is KNOWN to cause cancer, so don't do this in closed garage... and wear thick, rubber "dishwashing" gloves.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Best way to remove layers of paint from pot metal? [Re: RTSrunner] #2227961
01/05/17 05:55 PM
01/05/17 05:55 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
RT
You can lay some clean mechanics rags after you apply the stripper to help prevent evaporation also if you want to continually work on them.. Apply some stripper to the rags also to keep them wet....
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2227981
01/05/17 06:26 PM
01/05/17 06:26 PM
E
earlymopar Offline
earlymopar  Offline
E
I'm an engineer and have spent many years with die-cast zinc parts, commonly known as "pot-metal". The blistering issue is created from voids (trapped air) in the die cast part and blasting the part causes air that is close to the surface to heat up and expand. Often you will see delamination of the surface as well but that is usually at a low enough level that it doesn't cause cosmetic problems. The same blistering symptom can also be seen when heating die cast parts for any secondary process such as with the powder coat curing process.
- EM
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2228189
01/05/17 10:36 PM
01/05/17 10:36 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
"blasting the part causes air that is close to the surface to heat up and expand" Again, seriously ?!?!? Just how much heat are we talking here ... are you blasting with air pre-heated in a blast furnace or what? The jet of air from the blaster is cooling the part as fast as the friction is heating it. I've never had a blasted part that was even "warm" to the touch. I know for a fact sheet metal will warp from sandblasting but blistering pot metal in a blast cabinet is a little hard to believe. And IF that's happening then you need to change your technique !!!
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2228210
01/05/17 10:51 PM
01/05/17 10:51 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Talk to your plater...
Re: Best way to remove layers of paint from pot metal? [Re: RTSrunner] #2228250
01/05/17 11:20 PM
01/05/17 11:20 PM
IN
ahy Offline
ahy  Offline
IN
RT
This would be my suggestion also. Plastic bag or wrap in plastic. Give it some time and it really helps. Even an hour helps... apply goop, wrap it up, gently scrape and repeat if needed.
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2228292
01/05/17 11:59 PM
01/05/17 11:59 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
If it was me I would just use a da and be done with it.
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2228312
01/06/17 12:22 AM
01/06/17 12:22 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Either brake fluid or lacquer thinner, in a sealed, closed container. Submerge the parts, seal, and walk away for a few weeks. Carb dip may also work.
Re: Best way to remove layers of paint from pot metal? [Re: Michael Ecks] #2228546
01/06/17 12:53 PM
01/06/17 12:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Brake fluid seems to work on non-epoxy paints.
