Best way to remove layers of paint from pot metal?
#2227435
01/04/17 11:01 PM
01/04/17 11:01 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Just bought a pair of quarter panel scoops for my 71 Challenger. chipped areas indicate they've been through at least 5 different pain jobs over the years. Aircraft Paint Stripper peeled up the very top coat and that was all.
Had bad luck with sand/bead blasters blistering pot metal.
What's the best way to clean up parts like this?
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Best way to remove layers of paint from pot metal?
[Re: Michael Ecks]
#2227494
01/05/17 12:06 AM
01/05/17 12:06 AM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Crushed walnut shells? I would think any type of media that does not create heat.
[Re: Michael Ecks]
#2227510
01/05/17 12:21 AM
01/05/17 12:21 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: Michael Ecks]
#2227529
01/05/17 12:50 AM
01/05/17 12:50 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
One application of stripper will not take off 5 layers of paint. Keep trying.
[Re: Michael Ecks]
#2227871
01/05/17 03:38 PM
01/05/17 03:38 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I agree with the stripper idea. The key ingredient in it you're looking for is "methylene chloride" aka "dichloromethane" which will strip even industrial epoxies, urethanes, acrylics..... all paints that I know of. It doesn't work fast (a few days maybe) & it is KNOWN to cause cancer, so don't do this in closed garage... and wear thick, rubber "dishwashing" gloves.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: RTSrunner]
#2227961
01/05/17 05:55 PM
01/05/17 05:55 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Apply the aircraft stripper again and put it in a heavy plastic bag & tie it shut.It will not evaporate this way and will soften more of the paint. Be patient,a few hours or overnite to set.Pull from bag,scrape with a plastic scraper,or carefully with a razor and repeat as necessary.You can go over it with paint stripper and a scotch brite pad to finish,then wash with water to neutralize.Fine blasting can clean and detail it for paint prep. RT You can lay some clean mechanics rags after you apply the stripper to help prevent evaporation also if you want to continually work on them.. Apply some stripper to the rags also to keep them wet....
[Re: Michael Ecks]
#2228210
01/05/17 10:51 PM
01/05/17 10:51 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
What's the best way to clean up parts like this? Talk to your plater...
[Re: RTSrunner]
#2228250
01/05/17 11:20 PM
01/05/17 11:20 PM
Posts: 7,664 IN
ahy
IN
Apply the aircraft stripper again and put it in a heavy plastic bag & tie it shut.It will not evaporate this way and will soften more of the paint. Be patient,a few hours or overnite to set.Pull from bag,scrape with a plastic scraper,or carefully with a razor and repeat as necessary.You can go over it with paint stripper and a scotch brite pad to finish,then wash with water to neutralize.Fine blasting can clean and detail it for paint prep. RT This would be my suggestion also. Plastic bag or wrap in plastic. Give it some time and it really helps. Even an hour helps... apply goop, wrap it up, gently scrape and repeat if needed.
