Restoration group 24 battery #2227094
01/04/17 02:21 PM
01/04/17 02:21 PM
Central KS
Fred_Gilmore Offline OP
Central KS
I was waiting for my yellow cap battery to die and it finally did... I have seen where guys have done this on a red cap group 27 but not a yellow 24 so I thought I would give it a shot. Seems to have worked out fine. I have lots of other pictures if anyone needs to see anything else.
Re: Restoration group 24 battery [Re: Fred_Gilmore] #2227124
01/04/17 03:03 PM
01/04/17 03:03 PM
WA
tman Online content
tman  Online Content
WA
Does your car start up well? Nice job! List the supplies/fasteners that you used for hook up.
Re: Restoration group 24 battery [Re: Fred_Gilmore] #2227208
01/04/17 05:15 PM
01/04/17 05:15 PM
Central KS
Central KS
Battery is in a T/A and seems to crank fine. I doubt it would work very well in Minnesota outside in January... Cable connectors are just from my junk box of salvaged electrical panels except for the ones coming off the battery. Those I made. Just be prepared to take some time to remove all the plates and dividers.
Re: Restoration group 24 battery [Re: Fred_Gilmore] #2227325
01/04/17 08:29 PM
01/04/17 08:29 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Nice job.I would like to see some pics of the connections.
Re: Restoration group 24 battery [Re: 5carguy] #2227331
01/04/17 08:41 PM
01/04/17 08:41 PM
Central KS
Central KS
Not really too much to see. The bottom connectors just bolt directly down to what was left of the post connectors. I bored and tapped a 1/4x28 thread right into the lead. Just be careful when tightening as to not pull the threads out of the lead.
Re: Restoration group 24 battery [Re: Fred_Gilmore] #2227913
01/05/17 04:40 PM
01/05/17 04:40 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Nice work. Did the same thing with a red top but the PC925 would not turn over my 440-6 when it was hot. Cold fine.
Re: Restoration group 24 battery [Re: Fred_Gilmore] #2228098
01/05/17 08:48 PM
01/05/17 08:48 PM
WA
tman Online content
tman  Online Content
WA
Is there a slightly larger spec battery that would fit in a Red top?
