Can i reuse my flex plate #2226782
01/04/17 12:10 AM
01/04/17 12:10 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Would like opinions on reusing the flex plate from my SB on the new 511 combo?
Re: Can i reuse my flex plate [Re: mopar dave] #2226791
01/04/17 12:16 AM
01/04/17 12:16 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
No ......... I wouldn't .. They are cheap insurance.. Why not buy what you need ..
Re: Can i reuse my flex plate [Re: 70dusterjohn] #2226814
01/04/17 12:38 AM
01/04/17 12:38 AM
Mt Morris Michigan
Mt Morris Michigan
What style and brand would be best?
Re: Can i reuse my flex plate [Re: mopar dave] #2226831
01/04/17 12:57 AM
01/04/17 12:57 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run an SFI B&M full circle unit.........
Re: Can i reuse my flex plate [Re: Thumperdart] #2226854
01/04/17 01:27 AM
01/04/17 01:27 AM
Mt Morris Michigan
Mt Morris Michigan
I was just looking at those. Thanks Dom.
Re: Can i reuse my flex plate [Re: mopar dave] #2226865
01/04/17 01:47 AM
01/04/17 01:47 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I run the same one as Dom on my 451
eBay-cdwmotorsports
Re: Can i reuse my flex plate [Re: cdwmotorsports] #2226901
01/04/17 02:50 AM
01/04/17 02:50 AM
Mt Morris Michigan
Mt Morris Michigan
looks like there is more than 1 part number on those flex plates. what number should I have for BB 6 bolt with 727?
Re: Can i reuse my flex plate [Re: mopar dave] #2226903
01/04/17 03:02 AM
01/04/17 03:02 AM
Martinsville, IN
Martinsville, IN
10230 is the one I have
eBay-cdwmotorsports
Re: Can i reuse my flex plate [Re: mopar dave] #2226904
01/04/17 03:10 AM
01/04/17 03:10 AM
If they both have the same bolt patterns why not shruggy I have reuse stock ones for years, especially the 11 inch big bolt pattern (7/16 converter bolts) M.W. and the stock 8 bolt pattern 426 street Hemi ones up
Re: Can i reuse my flex plate [Re: Cab_Burge] #2226916
01/04/17 03:37 AM
01/04/17 03:37 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Sure you can if it matches your converter,crank and balance situation. Not enough info to really help.
Re: Can i reuse my flex plate [Re: J. Hammer] #2227025
01/04/17 12:40 PM
01/04/17 12:40 PM
Mt Morris Michigan
Mt Morris Michigan
the old one is off my 4" SB eagle crank and its the 4 leaf style. does look like theres anything wrong with it. Would be going on a molnar 4.25 BB crank. Both cranks are 6 bolt.
Re: Can i reuse my flex plate [Re: mopar dave] #2227033
01/04/17 12:57 PM
01/04/17 12:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On those square flex plates mopar made 2 of
them.. one 6 bolt and one 8 bolt.. I'm talking
the SFI with the bigger bolts for the conv.. but
if you have a BB or a SB the same flex fits.. I
have used mine on about 6 engines over the years
and got the round one for my R3-W-9.... look it
over closely.. if its not cracked.. put it on
wave
Re: Can i reuse my flex plate [Re: mopar dave] #2227057
01/04/17 01:20 PM
01/04/17 01:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don't like the wimpy star flexplates and cracked a few over the years hence the reason for the B&M full circle plate. Order the one based on the balance weather internal or external...........mines 15+ years old..........
Re: Can i reuse my flex plate [Re: MR_P_BODY] #2227076
01/04/17 01:55 PM
01/04/17 01:55 PM
Mt Morris Michigan
Mt Morris Michigan
I got this one from a friend that bought it for his 440 and never used it. It was on my SB since 02. It might be time to retire it.
Re: Can i reuse my flex plate [Re: mopar dave] #2227161
01/04/17 03:43 PM
01/04/17 03:43 PM
Dominic, Thumperdart, is correct about the light duty stock ones cracking, I've seen several like that down
I've never heard or saw a stock full size solid Mopar flex plate break or crack shruggy
Mopar used the exact same cores for their SFI plates they sold and added more money onto them for that SFI tag shruggy
I have never seen or heard of any NHRA or track tech at a drag race crawl under the car to look at the SFI tags on the tranny , flex plate or flywheel shield shruggy
Re: Can i reuse my flex plate [Re: Cab_Burge] #2227177
01/04/17 04:18 PM
01/04/17 04:18 PM
Mt Morris Michigan
Mt Morris Michigan
prw any good
Re: Can i reuse my flex plate [Re: mopar dave] #2227197
01/04/17 04:54 PM
01/04/17 04:54 PM
I have no idea on them, I would go to my local Dodge or Chrysler dealer and see how much a new HD one is, non SFI devil Mopar made four solid HD ones with the 7/16 converter bolts, 6 and 8 bolt non SFI for all the stock motors that came with the converters with the 7/16 bolts and the other two where the same ones with SFI stickers on them shruggy
They also made two different sizes of the standard light duty OEM ones for both 11 and 12 inch converters with the 5/16 converter bolts, they where for six bolt crankshaft flanges only though shruggy
If yours is in decent shape and reusable I would probably reuse it thumbs shruggy
Re: Can i reuse my flex plate [Re: Cab_Burge] #2227202
01/04/17 05:00 PM
01/04/17 05:00 PM
Mt Morris Michigan
Mt Morris Michigan
Mine is the 4 leaf style. Would like to up grade to the round style. Thanks cab
Re: Can i reuse my flex plate [Re: mopar dave] #2227225
01/04/17 05:43 PM
01/04/17 05:43 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
The PRW are great for the cost. Some of the diesel guys are running 1000hp thru the platinum series ones and I have never head of a failure.
Damon
Re: Can i reuse my flex plate [Re: mopar dave] #2227350
01/04/17 09:09 PM
01/04/17 09:09 PM
Your making the correct choice, don't take any chances on race parts thumbs
I have seen racer drill out the stock leaf style 5/16 holes to 7/16 bolt sizes and then had them fail completely at the races puke shruggy
