Re: Anyone here painted their engine black? [Re: fullmetaljacket] #2222691
12/29/16 11:44 AM
12/29/16 11:44 AM
Fullmetaljacket that does explain it & makes sense as this would be two different heat sources, one inside (eng heat) the other external (the suns heat) on a roof.
Re: Anyone here painted their engine black? [Re: 1970RT] #2222734
12/29/16 01:26 PM
12/29/16 01:26 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
If you want to be able to find and fix leaks, paint it another color.
If you don't care about small leaks and don't want them to be noticeable, then paint it black.
smile
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Anyone here painted their engine black? [Re: 1970RT] #2223130
12/30/16 01:41 AM
12/30/16 01:41 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Black heads and block, black headers, black pulleys, natural aluminum intake, radiator, steering parts, black rubber and stainless steel braid hoses with steel ends, chrome pieces here and there. IMO, I prefer only having a few colors in the engine bay. It tends to clean it up and simplify it rather than looking like a carnival of colors.
Re: Anyone here painted their engine black? [Re: 1970RT] #2224039
12/31/16 02:25 PM
12/31/16 02:25 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
I paint all my engines black.
It does make it hard to find an oil leak if you have one but I like the look. I think it sets off the look of aluminum or chrome.
I have aluminum heads which I left unpainted.
Re: Anyone here painted their engine black? [Re: patosmith] #2224149
12/31/16 05:38 PM
12/31/16 05:38 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The next time you are over to my shop, Pat I can show you a black painted 400 block with Aluminum heads, a couple of 440 MH blocks (one which is complete with MH 727), a 440 Truck block with no ridge and a 440 race motor with iron "906" heads that went 11.33 in a Duster and will go into the Cuda as a mule.
There will be club clinics in 2017.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Anyone here painted their engine black? [Re: Polarapete] #2225581
01/02/17 02:41 PM
01/02/17 02:41 PM
P
patosmith Offline
patosmith  Offline
P
Hi Pete,
Give me a heads up on the clinics!
I will plan a visit to your shop.
Re: Anyone here painted their engine black? [Re: 1970RT] #2225607
01/02/17 03:16 PM
01/02/17 03:16 PM
Utah, USA
1964superstock Offline
Utah, USA
How does the engine know what color it is painted? I can see if sunlight is hitting an object painted black or white and the black painted object absorbs the sunlight, and the white reflects it. However, under a hood, how does engine color affect anything? Is orange paint, blue paint, or red paint made of completely different chemicals than black paint?
Re: Anyone here painted their engine black? [Re: 1964superstock] #2225700
01/02/17 05:10 PM
01/02/17 05:10 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I think that the best color for an engine is to paint it industrial gray, because you can better spot leaks of all kinds against a gray background and white is just too much to keep clean, but whatever blows your dress up!!
2008 Honda Element
Re: Anyone here painted their engine black? [Re: Polarapete] #2225748
01/02/17 06:22 PM
01/02/17 06:22 PM
Pete do you have a recommended brand/part # for industrial grey. A good company like Rustoleum or similar.
Re: Anyone here painted their engine black? [Re: RapidRobert] #2225783
01/02/17 07:00 PM
01/02/17 07:00 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
VHT and Duplicolor do a gray engine paint (Ford had used gray from the factory I believe)
A buddy in Oz did a grey on a tractor engine from memory, it was just some general industrial sort of engine? paint I think. (been a while)
Re: Anyone here painted their engine black? [Re: 1970RT] #2225910
01/02/17 10:16 PM
01/02/17 10:16 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Been painting them gloss black since the 70s. Next one will be black, too.
Re: Anyone here painted their engine black? [Re: 1970RT] #2226636
01/03/17 10:11 PM
01/03/17 10:11 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Gross
Re: Anyone here painted their engine black? [Re: OzHemi] #2226700
01/03/17 11:08 PM
01/03/17 11:08 PM
Thanks Oz
Re: Anyone here painted their engine black? [Re: GTX MATT] #2226984
01/04/17 11:01 AM
01/04/17 11:01 AM
6T4 Polara Offline
6T4 Polara  Offline
When I had a GN Buick I did.
Re: Anyone here painted their engine black? [Re: 1970RT] #2226992
01/04/17 11:26 AM
01/04/17 11:26 AM
SW MO
closer9 Offline
closer9  Offline
SW MO
This is an old pic, but I used POR15's engine kit. I've done several. The plus is it helps hide oil leaks, the minus is it helps hide oil leaks.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Anyone here painted their engine black? [Re: 1970RT] #2227382
01/04/17 09:55 PM
01/04/17 09:55 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Conversely,I plat to paint the Gen III Hemi in my 2004 Durango Hemi Orange. I need some contrast so I can see when installing it!
