How about this bearing wear pattern? #2225715
01/02/17 04:29 PM
01/02/17 04:29 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
All main bearings looks very good except nr 3.
Stock bottom magnum engine with about 100k miles.
Should i worry or just put new bearings in it?
Re: How about this bearing wear pattern? [Re: sshemi] #2225723
01/02/17 04:43 PM
01/02/17 04:43 PM
Washington
madscientist Offline
Washington
New bearings, and line hone to set the clearance.
Re: How about this bearing wear pattern? [Re: sshemi] #2225750
01/02/17 05:23 PM
01/02/17 05:23 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How did the last set off bearings look?Did you change anything?
Re: How about this bearing wear pattern? [Re: sshemi] #2225778
01/02/17 05:50 PM
01/02/17 05:50 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
The ones pictured are the originals.
Re: How about this bearing wear pattern? [Re: sshemi] #2225792
01/02/17 06:17 PM
01/02/17 06:17 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
What's the crankshaft #3 main journal look like?
Re: How about this bearing wear pattern? [Re: John_Kunkel] #2225806
01/02/17 06:42 PM
01/02/17 06:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With 100K on it... put new bearings in
wave
Re: How about this bearing wear pattern? [Re: sshemi] #2225849
01/02/17 07:47 PM
01/02/17 07:47 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Well you may as well mic the crank for the heck of it.
Re: How about this bearing wear pattern? [Re: sshemi] #2225864
01/02/17 08:04 PM
01/02/17 08:04 PM
Az
Crizila Offline
Crizila  Offline
Az
Even thought lots of miles, I would still try and find the cause. Tight clearance, restricted oil passage, etc. If you can't definitively find something, for sure line bore it - and check rotational torque upon reassembly.
Fastest 300
Re: How about this bearing wear pattern? [Re: sshemi] #2225870
01/02/17 08:15 PM
01/02/17 08:15 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Crank is mint.
Had great oil pressure.
Dont have new bearings yet but if my math is correct bearing clearence will be way too little with new bearings. Check it throughly and the reason for the bearing to look like that is from several factors all beeing on the same side of tolerances making clearence too small.
I think/hope a linehone will fix it.
Re: How about this bearing wear pattern? [Re: sshemi] #2225873
01/02/17 08:24 PM
01/02/17 08:24 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By sshemi
Crank is mint.
Great oil pressure wont see a {possible} restricted feed to that journal. Its not unheard of for the oil feed channels to have casting flash in them. Id run a reamer through that oil feed for sure. Along with measuring the bearing clearance on it as well. A line hone isn't a bad idea, but probably overkill, unless its going to be a race motor.
Re: How about this bearing wear pattern? [Re: sshemi] #2225944
01/02/17 09:54 PM
01/02/17 09:54 PM
I would check the center main journal for run out twocents Even .0003 can cause that center main bearing to look like that with stock, tight bearing clearances shruggy scope
Re: How about this bearing wear pattern? [Re: sshemi] #2225999
01/02/17 10:59 PM
01/02/17 10:59 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Crank is mint.
is there an .001 bearing for it?What oil did you run?
Re: How about this bearing wear pattern? [Re: Cab_Burge] #2226060
01/02/17 11:58 PM
01/02/17 11:58 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
What Cab said
Exactly what I was thinking Cab. Have the center journal checked for a high spot.
Old Geezer Racing
Re: How about this bearing wear pattern? [Re: SCATPACK 1] #2226163
01/03/17 05:34 AM
01/03/17 05:34 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Main bores are out of round .0008. Crank is bent .0002 but perfect journals. Rods are also .0008 out of round but all rod bearings looks normal.
All oil passages are good.
Re: How about this bearing wear pattern? [Re: sshemi] #2226174
01/03/17 07:26 AM
01/03/17 07:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It's hard to see in the pic but it looks like high mileage "fretting" to me. Make sure you have enough clearance and run it.
Doug
Re: How about this bearing wear pattern? [Re: sshemi] #2226343
01/03/17 02:09 PM
01/03/17 02:09 PM
I would put a set of full groove main bearings and a set of race type rod bearings in it so they have more clearances like .0025+ on the rods and .003+ on the mains twocents
I've had several stock production early 1970s 318 motors that had the #2 main journal out of round and bent .001+ which I ended up having to use scotch brtite on that main bearing to get additional clearnces so the motor would run. Looking back now I should have used a set of 340 full groove main bearings in them shruggy
Good luck on your deal thumbs
Re: How about this bearing wear pattern? [Re: sshemi] #2226389
01/03/17 03:05 PM
01/03/17 03:05 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Rods have plenty of clearence as the rod bore is on the bigger side. Actually a bit too big.
Ill check main clearence with plasti gauge. I have never used it but i feel on this i need to.
Or just spend the $400 the machine shop wants to correct it all.
That includes cylinder hone also.
Re: How about this bearing wear pattern? [Re: sshemi] #2226457
01/03/17 04:53 PM
01/03/17 04:53 PM
Washington
Washington
That'll be the best 400 dollars you can spend. The mains need a hone and the rods resized.
