Jomar High flow oil filter , no by-pass valve #1715590
12/25/14 08:19 PM
12/25/14 08:19 PM
Missouri
DC416 Offline OP
DC416  Offline OP
Missouri
Has anybody ran these filters on a street car, and are they any good?
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #1715591
12/25/14 10:05 PM
12/25/14 10:05 PM
pa
gregcharger72 Offline
pa
I run this filter on my street/strip car and have no issues. But I only drive about 3-400 miles a year on the street and change my oil twice a year. The filter is recommended by Hughes Engines.
Re: Jomar High flow oil filter , no by-pass valve [Re: gregcharger72] #1715592
12/26/14 12:39 AM
12/26/14 12:39 AM
Missouri
DC416 Offline OP
DC416  Offline OP
Missouri
Thanks. I knew they sold them, wasnt sure if you could run it on a street car.
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #1715593
12/26/14 03:53 PM
12/26/14 03:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yes, and with no problems.
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #1715594
12/26/14 05:15 PM
12/26/14 05:15 PM
I think all the oil filters used on Chevy motors have no internal bypass valves in them like the Ford and Mopar oil filters do I have seen a lot of the oil bypass valves in the adapters on Chevy motors epoxy closed The System One oil filters have a internal bypass built into them that could be epoxy closed
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #1715595
12/26/14 05:23 PM
12/26/14 05:23 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Some good info in this thread at YB (relatively work safe). Not only does he cut open the filters, he contacts the manufacturers for data. Many, but not all, provide specs. (Yes a Jomar is in there)
http://www.yellowbullet.com/forum/showthread.php?s=1ddbc7c13ba0ea7f00784fec4c69bcaf&t=420509
Re: Jomar High flow oil filter , no by-pass valve [Re: Mattax] #1715596
12/26/14 11:02 PM
12/26/14 11:02 PM
Missouri
DC416 Offline OP
DC416  Offline OP
Missouri
Great Info! Thanks
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #1715597
12/26/14 11:26 PM
12/26/14 11:26 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
My moroso oil filter doesn't have a bypass neither and is one of the reasons I buy it. I was going to buy wix racing filters but their tech people are assholes and turned me away from them.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Jomar High flow oil filter , no by-pass valve [Re: slammedR/T] #1715598
12/27/14 02:07 PM
12/27/14 02:07 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I read that whole yellowbullet thread last night, very interesting. I never thought of the bypass the way they describe it, makes sense.
68 Barracuda Formula S 340
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #2225598
01/02/17 03:05 PM
01/02/17 03:05 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Am I correct in assuming, if you use a non bypass filter, and it starts plugging up, your oil pressure as shown from the gauge port at the rear, will drop proportionally?
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #2225619
01/02/17 03:35 PM
01/02/17 03:35 PM
crabman173
crabman173
Filter is made by Baldwin--long said to be the best by McCandless
we like them--safe to use in any application--anytime
It filters oil all the time like you would suspect should happen but doesn't
If it is plugging up you are blowing up so....best thing is it does not add to the problem
Jomar and guys that run it are fantastic folks and know what they are talking about you can call them direct for fast shipping and a no BS experience Love those guys!!!!
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #2225658
01/02/17 04:28 PM
01/02/17 04:28 PM
New York
polyspheric Online content
polyspheric  Online Content
New York
500 years ago Bill Jenkins recommended the AC832 truck filter, the canister is as big as a garbage can so it's safe without a bypass.
Safe is a relative term. Straight 60 weight and 20 degree oil temperature will blow almost anything off the engine even with a bypass - it's just too much pressure.
It also depends in part on what the capacity of the pump's pressure relief system - some are pretty small.
Boffin Emeritus
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #2225729
01/02/17 05:55 PM
01/02/17 05:55 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
So if the filter starts plugging up, will you see that as a decrease in idle oil pressure?
When oil pump speed come up with RPMs, would the oil pump bypass then allow normal pressure to oiling system?
Re: Jomar High flow oil filter , no by-pass valve [Re: 65Fury440] #2225859
01/02/17 09:02 PM
01/02/17 09:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most oil pressure relieve valves/springs are set
at 70 psi so it will by pass at that point.. BUT
flow is what your after.. if the filter plugged up
100%you have ZERO flow
EDIT
The pressure gauge is after the filter
wave
Re: Jomar High flow oil filter , no by-pass valve [Re: MR_P_BODY] #2225902
01/02/17 10:10 PM
01/02/17 10:10 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
EDIT
wave
If the gauge is after the filter, a restricted filter would show up as lower gauge pressure?
This will be on a weekend warrior engine, oil will never get dirty, just thinking it through.
I think this is how it would work, just wanted to run it by the discerning minds of Moparts.
Re: Jomar High flow oil filter , no by-pass valve [Re: DC416] #2226037
01/03/17 12:39 AM
01/03/17 12:39 AM
crabman173
crabman173
Geeezz! I have NEVER had a plugged filter in one of my Mopars street or race
If pressure is dropping you have a problem
Any filter will do and is not any problem
Never seen an engine failure due to a dang filter
Snap out of it!!!!
Re: Jomar High flow oil filter , no by-pass valve [Re: ] #2226058
01/03/17 12:57 AM
01/03/17 12:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Snap out of it!!!!
I have had a pressure drop of 20psi with a
Fram filter.. so did my brother and my buddy..
we dont use Fram filters anymore
wave
Re: Jomar High flow oil filter , no by-pass valve [Re: ] #2226088
01/03/17 01:31 AM
01/03/17 01:31 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I don't fully understand how the pump bypass would behave in a full or partial restriction, with a filter that doesn't have a bypass.
Re: Jomar High flow oil filter , no by-pass valve [Re: 65Fury440] #2226097
01/03/17 01:52 AM
01/03/17 01:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
IF the filter starts plugging up the back
pressure increases which puts more pressure
on the pump... the pump by pass opens up BUT
if the filter were totally plugged up the pump
by pass CANT handle the total flow of the pump..
but if your smart the gauge outlet would show
zero pressure and if you put a low pressure
switch on that point to the ignition it will
kill the engine
wave
Re: Jomar High flow oil filter , no by-pass valve [Re: MR_P_BODY] #2226104
01/03/17 02:00 AM
01/03/17 02:00 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
kill the engine
wave
Thanks for the explanation.
I always thought the pump bypass diverted back into the pan.
I am going to run the Jomars, ordered 3 from Jeg's.
I change the oil once a year, maybe go 2-3000 miles.
Oil pressure gauge should start to show a decrease with less flow.
Thanks again.
