Re: Upper Ball Joint question
[Re: OzHemi]
#222426
02/12/09 10:10 PM
02/12/09 10:10 PM
RapidRobert
they thread in and out. The new one CAN be a bit hard to start as they design an interference fit so it stays put so just make sure you start it "square" & I put some grease on the threads to ease future dissassembly. Some are self threading & cut their own threads but none(of our Mopars) are meant to be pressed in or out.
[Re: RapidRobert]
#222427
02/12/09 11:24 PM
02/12/09 11:24 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
If you press any uppers in a old Mopar the arms are junk period.They all screw in.Rocky
Chrysler Firepower
[Re: zrxkawboy]
#222431
02/14/09 12:59 AM
02/14/09 12:59 AM
Posts: 12,244 Looking for a way out of Middl...
IMGTX
Have you removed the nut from the bottom and used a ball joint fork to seperate the arm (ball joint stud) from the spindle casting?
+1
I didn't see from your response that you seperated the ball joint from the spindle and I think that this is where these guys are going.
+2
I had to press my ball joints in. They weren't threaded, they had parallel grooves that I had to press out.
The bolt in ball joints haved some very thin screw threads that look like parallel lines. You may have pressed in screw in ball joints. If so keep an eye on them. They can pull back out of the control arm, I have seen it happen.
If the ball joint does not have the 4 flats on the edges where it meets the control arm it is a press in ball joint. If it has the 4 flats it is a screw in in my experience. As somebody already said that year is going to be screw in.
[Re: 1fastrunner]
#222432
02/14/09 01:13 AM
02/14/09 01:13 AM
Andrewh
I removed the nut from the bottom, and used the socket to unscrew the top. It has stopped coming up even though it's still rotates. I didn't try to pry it out yet because I didn't want to mess up any threads by mistake. So, I just need to pry it out? Jim
can you compare it to the new one? See how much is still threaded in there? There might just be some metal shavings holding it in place depending on where the taper starts.
Is the whole thing spining, or just part of it? Pretty sure the casing that you turn has the threads. Are you turning by hand? or do you think it is turning because the socket is moving? That is, sometimes it seats a bit shallow, and the socket may move, but the balljoint doesn't.
[Re: 72roadrunnergtx]
#222434
02/14/09 02:24 AM
02/14/09 02:24 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
As I read the OP’s postings, I don’t hear that the upper ball joint has been separated from the spindle prior to attempting to remove the joint from the upper control arm. Assuming you are performing the repair on the car, Have you released the torsion bar tension yet? The method that works well for me is first before backing off on the torsion is to loosen, not remove, the spindle to ball joint nut and 1/8 inch or so and hitting the side of the spindle flange with a hammer to release the tapered stud. Back off the torsion bar completely, remove the nut to separate the ball joint from the spindle completely. Now the ball joint can be unscrewed from the control arm.
Well put, the stud has a nut that must removed and the stud is a Morse Taper that requires some effort to unseat from the spindle casting. After the torsion bar has been unscrewed.. I like a pickel fork and a BIG hammer to remove them..
