Re: installing windshield in a 67 B
[Re: MoparDan]
#2223371
12/30/16 02:41 PM
12/30/16 02:41 PM
Posts: 2,920 Calgary, Alberta Canada
a12rag
Check with a local glass shop . . . but on my 70 Sport Satellite, the rubber gasket went into the opening in the car first, and then the windshield set into the rubber. One thing to remember is to clean the metal on the opening really well, then on the bottom run a bead of butyl and up the sides about 6", THEN but the rubber in, then but the windshield in the rubber - that is what the FSM says for my 70. The glass shop didn't do it that way, and it leaks - will be going back to them in the spring to fix properly . . . mean they have to remove the windshield !!!
Anyhow, do a google search and you will probably find what the FSM for 67 B body shows (I am pretty sure it is same as 70 . . . but, you never know) . . .
Good luck,
[Re: MoparDan]
#2223512
12/30/16 06:25 PM
12/30/16 06:25 PM
Posts: 1,213 Minn
SportF
Minn
Looks like no one else is commenting, and I have done this 4-5 times, but never the way the pro's do it. Put rubber in the opening on the flange, but it will probably fall out at the top. Set the glass on it and start to work it into the rubber at the bottom.
Use a wooden paint stick, or plastic to help you move the rubber around the glass, and a strong dish soap solution to lubricate the rubber/glass.
DO NOT FORCE the glass, do not push down on the glass. From the bottom work up the sides and eventually the glass won't be laying on the rubber, but will go in and find its position in the car. But that won't happen until the very last of the rubber is plied around the glass. Again, dish soap lubricant is your friend and will help that last "slip into place"
This takes me 2-3 hours, and as you work up the pillars the glass will be farther out, but eventually go in towards the car and allow you to finish the top. If not, its because the glass is not sliding into the gasket in all places, lube it up and it will.
Good luck, remember do not force, do not push. The rubber will pull it into final position.
The new rubber will make this job much easier for us non-pro's.
[Re: SportF]
#2223957
12/31/16 12:29 PM
12/31/16 12:29 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
The new rubber will make this job much easier for us non-pro's. Times 2 on this method. I did it once and got away with it.Use lots of plastic or wood "pryin sticks", and don't hurry.Mine had a rubber bead which pushed into a groove in the rubber gasket to lock it in place. Like it was gonna jump out...
