Page 3 of 3 1 2 3
Re: odd vin or not? [Re: 52savoy] #2222388
12/28/16 08:01 PM
12/28/16 08:01 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it's not SUPER STOCK II 'til May '63 with the battery in the trunk (among other things)
Plymouth "MAX WEDGE" were officially:
1962 = 413 SUPER STOCK
1963 = 426 SUPER STOCK (I)
1963 = 426 SUPER STOCK II - started May '63
1964 = 426 SUPER STOCK III
low compression & high compression "MAX WEDGE" engines were available in each of the above model years & configurations
I think (advertised):
1962 413MW: LC = 405hp & HC = 420hp
1963 426MW: LC = 415hp & HC = 425hp
1964 426MW: LC = 415hp & HC = 425hp
Re: odd vin or not? [Re: 52savoy] #2222392
12/28/16 08:07 PM
12/28/16 08:07 PM
State of retirement
52savoy Offline OP
52savoy  Offline OP
State of retirement
Years ago when I had 1963 lc max wedges I assumed they were stage IIs but over time.. showed me that Chrysler made it really confusing....... Heads and carbs trunk mounted batteries and aluminum front ends.........GEEZ.
Re: odd vin or not? [Re: 52savoy] #2222447
12/28/16 09:59 PM
12/28/16 09:59 PM
State of retirement
52savoy Offline OP
52savoy  Offline OP
State of retirement
Might have proof of the changes between stage I and II's. Compare TSB #63-26B dated July 17,1963 and TSB 63-26 dated Dec 14,1962 and.. TSB 63-26A dated Jan 9 1963.
I've been through a few hundred and done for the day.
Re: odd vin or not? [Re: 52savoy] #2222686
12/29/16 11:39 AM
12/29/16 11:39 AM
moparx Online content
moparx  Online Content
are '286 iron heads worth fooling with to use on a mild build, or should a guy just jump to the newer aluminum heads which require a total go through anyway just to be sure on quality ?
beer
Page 3 of 3 1 2 3
