Re: Anyone here painted their engine black?
[Re: fullmetaljacket]
#2222691
12/29/16 11:44 AM
12/29/16 11:44 AM
RapidRobert
Fullmetaljacket that does explain it & makes sense as this would be two different heat sources, one inside (eng heat) the other external (the suns heat) on a roof.
[Re: 1970RT]
#2222734
12/29/16 01:26 PM
12/29/16 01:26 PM
Posts: 3,396 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
If you want to be able to find and fix leaks, paint it another color. If you don't care about small leaks and don't want them to be noticeable, then paint it black. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: 1970RT]
#2223130
12/30/16 01:41 AM
12/30/16 01:41 AM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
Black heads and block, black headers, black pulleys, natural aluminum intake, radiator, steering parts, black rubber and stainless steel braid hoses with steel ends, chrome pieces here and there. IMO, I prefer only having a few colors in the engine bay. It tends to clean it up and simplify it rather than looking like a carnival of colors. ![](http://i819.photobucket.com/albums/zz112/highplainsperformance/20150310_180301_zpsybrdk02i.jpg)
[Re: patosmith]
#2224149
12/31/16 05:38 PM
12/31/16 05:38 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The next time you are over to my shop, Pat I can show you a black painted 400 block with Aluminum heads, a couple of 440 MH blocks (one which is complete with MH 727), a 440 Truck block with no ridge and a 440 race motor with iron "906" heads that went 11.33 in a Duster and will go into the Cuda as a mule.
There will be club clinics in 2017.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#2225581
01/02/17 02:41 PM
01/02/17 02:41 PM
Posts: 295 Spanaway, Washington State
patosmith
There will be club clinics in 2017. Hi Pete, Give me a heads up on the clinics! I will plan a visit to your shop.
[Re: 1964superstock]
#2225700
01/02/17 05:10 PM
01/02/17 05:10 PM
Polarapete
Graham, WA
I think that the best color for an engine is to paint it industrial gray, because you can better spot leaks of all kinds against a gray background and white is just too much to keep clean, but whatever blows your dress up!!
[Re: Polarapete]
#2225748
01/02/17 06:22 PM
01/02/17 06:22 PM
RapidRobert
Pete do you have a recommended brand/part # for industrial grey. A good company like Rustoleum or similar.
[Re: RapidRobert]
#2225783
01/02/17 07:00 PM
01/02/17 07:00 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Pete do you have a recommended brand/part # for industrial grey. A good company like Rustoleum or similar. VHT and Duplicolor do a gray engine paint (Ford had used gray from the factory I believe) A buddy in Oz did a grey on a tractor engine from memory, it was just some general industrial sort of engine? paint I think. (been a while)
[Re: OzHemi]
#2226700
01/03/17 11:08 PM
01/03/17 11:08 PM
RapidRobert
Pete do you have a recommended brand/part # for industrial grey. A good company like Rustoleum or similar. VHT and Duplicolor do a gray engine paint (Ford had used gray from the factory I believe) A buddy in Oz did a grey on a tractor engine from memory, it was just some general industrial sort of engine? paint I think. (been a while) Thanks Oz
