Re: How tight should my wristpins fit???
[Re: mikemotorhead]
#222106
02/12/09 01:13 PM
02/12/09 01:13 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Should they rotate freely in the piston of fit pretty tight?? Thanks Mike
I have said it before on here, and most agree. NOTHING should be trusted out of the box. It should be your responsibility to test fit everything, and you are correct for asking. They should fall right out. I accually took a set of press fit mopar small block rods and for a project reamed out the small end, burnished in a bushing, and honed them to fit and the spec was .005.
I just spent a crap load of cash on a rotating assy with known good parts from a VERY reputable guy (DRAM), and I an meticulously checking everything.
[Re: Cab_Burge]
#222108
02/12/09 02:23 PM
02/12/09 02:23 PM
Posts: 15,493 the boonies
aarcuda
the boonies
Are you sure the clearance you ended up with was five thousands (.005) and not one one half of a thousand, .0005. If it is .005 you need to fix that now I like .0008 to .001 on a drag motor that will be RPM when the motor and oil are not hot
.005 is WAAAAAAAAAY loose. somethings gunna blow
[Re: Moparnut426]
#222110
02/12/09 05:16 PM
02/12/09 05:16 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
General spec on pin fit in the piston is .0003 to .0005.pin fit in a floating pin rod is generally .0005 to .0007.
Be a Rebel- Break the Laws of Physics!
