Re: Article on Muscle Motors new block
[Re: ]
#2220350
12/24/16 07:04 PM
12/24/16 07:04 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
I wonder why they didnt go ahead and drill the cross bolts on #5 specially since its prepped for it.. but at least there is a STRONG block for the BB guys... my mega block with 4.5 bores only had .200 walls at the thinnest point.. whats the next ring size over a 4.5.. does chevy have a 4.6 ring 4.600 and 4.625 are common sizes for BBC 565 cu in strokers in 9.8 deck Dart Big M blocks....lots of rings available....I'm learning it all for S/C and S/P racing....it's like learnig to speak all over again. Also in the 10.2 deck heights. Yup....but I'm finding "most" S/C dragsters are running 9.8 565-585" motors..they all say the short deck blocks work better with T stops..who knows...just following the herd...LOL
[Re: ScottSmith_Harms]
#2220430
12/24/16 09:52 PM
12/24/16 09:52 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Looks like a cool piece but for the money I think I'll be buying a Kieth Black aluminum block from FHO when he gets up and running with them. For a street car the light weight and repairability makes the most sense to me. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I just bought an Indy aluminum block. Close to the same money, but 200 pounds lighter!!!No brainer....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#2220949
12/26/16 02:31 AM
12/26/16 02:31 AM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Looks like a cool piece but for the money I think I'll be buying a Kieth Black aluminum block from FHO when he gets up and running with them. For a street car the light weight and repairability makes the most sense to me. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I just bought an Indy aluminum block. Close to the same money, but 200 pounds lighter!!!No brainer.... Did you get the Hemi or Wedge?
[Re: AndyF]
#2220956
12/26/16 03:01 AM
12/26/16 03:01 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That iron Block may have more HP capacity than aluminum.
Mopar to the bone!!!
[Re: Dragula]
#2221058
12/26/16 01:38 PM
12/26/16 01:38 PM
Old School
Virginia Beach, VA
Looks like a cool piece but for the money I think I'll be buying a Kieth Black aluminum block from FHO when he gets up and running with them. For a street car the light weight and repairability makes the most sense to me. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I just bought an Indy aluminum block. Close to the same money, but 200 pounds lighter!!!No brainer.... Did you get the Hemi or Wedge? I bought the RB wedge block. I had Todd Marsh build a 588 with it. It made 961 horsepower and 850 torque. I don't know how much more it would have made with an iron block ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: Old School]
#2221161
12/26/16 04:05 PM
12/26/16 04:05 PM
BradH
... I just bought an Indy aluminum block. Close to the same money, but 200 pounds lighter!!!No brainer.... What sort of additional work was required w/ the Indy block to make it "ready to assemble", and would you be willing to give an approximate cost of what the block plus any necessary finishing work totaled?
[Re: AndyF]
#2221212
12/26/16 05:28 PM
12/26/16 05:28 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
200 pounds lighter? Really? Was it filled with helium? ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) I was at a shop when they weighed a 4.5 bore iron mopar megablock. 230 pounds. How much is the new muscle motors iron block supposed to weigh? How much does in Indy aluminum block away?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: A39Coronet]
#2221256
12/26/16 07:13 PM
12/26/16 07:13 PM
Posts: 675 MI
MI Mopar Works
MI
Wonder if this will have any impact on the price of OEM blocks. Some of the guys in my area think a 74' 440 is made out of 24k gold. Doubtful, considering it is missing the tell-tale flat ID pad on the front of the block casting. No resto guy will want a Hemi that looks like a 383 block with auxiliary oil pump block off plugs.
[Re: MI Mopar Works]
#2221274
12/26/16 07:52 PM
12/26/16 07:52 PM
Posts: 3,396 Pa
Hot 340
Pa
Wonder if this will have any impact on the price of OEM blocks. Some of the guys in my area think a 74' 440 is made out of 24k gold. Doubtful, considering it is missing the tell-tale flat ID pad on the front of the block casting. No resto guy will want a Hemi that looks like a 383 block with auxiliary oil pump block off plugs. Who cares about them. The "resto" guys have ruined this hobby.
[Re: Hemi_Joel]
#2221286
12/26/16 08:17 PM
12/26/16 08:17 PM
Old School
Virginia Beach, VA
200 pounds lighter? Really? Was it filled with helium? ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) I was at a shop when they weighed a 4.5 bore iron mopar megablock. 230 pounds. How much is the new muscle motors iron block supposed to weigh? How much does in Indy aluminum block away? Really! My 4.530 mega block weighs 330 pounds. The indy block weighs 130 pounds. a stock block weighs 230 pounds. Sooo my Indy block is 200 pounds lighter than a mega block. And probably about the same for this new muscle motors block....
[Re: BradH]
#2221294
12/26/16 08:23 PM
12/26/16 08:23 PM
Old School
Virginia Beach, VA
... I just bought an Indy aluminum block. Close to the same money, but 200 pounds lighter!!!No brainer.... What sort of additional work was required w/ the Indy block to make it "ready to assemble", and would you be willing to give an approximate cost of what the block plus any necessary finishing work totaled? Hey Brad. the block was $4835. cnc clearance for the large stroke was $250. large bore sleeves were $100. total was about $5185.00. boring honing ect...would be the same as any block.
[Re: Old School]
#2221311
12/26/16 08:59 PM
12/26/16 08:59 PM
Hemi_Joel
Minnesota
200 pounds lighter? Really? Was it filled with helium? ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) I was at a shop when they weighed a 4.5 bore iron mopar megablock. 230 pounds. How much is the new muscle motors iron block supposed to weigh? How much does in Indy aluminum block away? Really! My 4.530 mega block weighs 330 pounds. The indy block weighs 130 pounds. a stock block weighs 230 pounds. Sooo my Indy block is 200 pounds lighter than a mega block. And probably about the same for this new muscle motors block.... Wow, what version of megablock is it? This 230 pounder was an early mopar mega block that was furnished with a 4.19 ruff bore, then finish bored to 4.5. I have a mega in storage that I'm going to dig out and weigh.
[Re: Old School]
#2221313
12/26/16 09:07 PM
12/26/16 09:07 PM
Posts: 9,883 MI, usa
dvw
MI, usa
200 pounds lighter? Really? Was it filled with helium? ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) I was at a shop when they weighed a 4.5 bore iron mopar megablock. 230 pounds. How much is the new muscle motors iron block supposed to weigh? How much does in Indy aluminum block away? Really! My 4.530 mega block weighs 330 pounds. The indy block weighs 130 pounds. a stock block weighs 230 pounds. Sooo my Indy block is 200 pounds lighter than a mega block. And probably about the same for this new muscle motors block.... I weighed my Mopar Mega-Block last year as I was contemplating an aluminum block. It weighed 270 lbs. 4.500 bore, motor mounts trimmed. Indy states 133lbs for 137 lb weight saving. Doug
[Re: Hemi_Joel]
#2221322
12/26/16 09:17 PM
12/26/16 09:17 PM
Old School
Virginia Beach, VA
200 pounds lighter? Really? Was it filled with helium? ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) I was at a shop when they weighed a 4.5 bore iron mopar megablock. 230 pounds. How much is the new muscle motors iron block supposed to weigh? How much does in Indy aluminum block away? Really! My 4.530 mega block weighs 330 pounds. The indy block weighs 130 pounds. a stock block weighs 230 pounds. Sooo my Indy block is 200 pounds lighter than a mega block. And probably about the same for this new muscle motors block.... Wow, what version of megablock is it? This 230 pounder was an early mopar mega block that was furnished with a 4.19 ruff bore, then finish bored to 4.5. I have a mega in storage that I'm going to dig out and weigh. My mega block is an earlier one, maybe around 96_98 or so. It has the engine mounts on it still. And had no lightning done to it at all. It is a heavy biatch
[Re: AndyF]
#2221338
12/26/16 09:45 PM
12/26/16 09:45 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Looks like a great start to me. We need more options. As much as Id like to take weight off the car. This block looks like it will hold a butt load of boost. I wanna find out!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: Hot 340]
#2221358
12/26/16 10:25 PM
12/26/16 10:25 PM
Posts: 1,115 Usa
A39Coronet
Usa
Wonder if this will have any impact on the price of OEM blocks. Some of the guys in my area think a 74' 440 is made out of 24k gold. Doubtful, considering it is missing the tell-tale flat ID pad on the front of the block casting. No resto guy will want a Hemi that looks like a 383 block with auxiliary oil pump block off plugs. Who cares about them. The "resto" guys have ruined this hobby. I blame the companies who are remaking parts. Rather than make $10 off 100 people, they want $100 off 10 people. But that's business, if it bothered me enough I'd be making OE dashboards and grills in my basement.
