Factory roller LA 360 aftermarket cams? #2219877
12/23/16 10:32 PM
12/23/16 10:32 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Was there or is there an aftermarket cam for the roller LA engines? I am
Building up a mild 325-350 hp 360. Would like to stay roller. I'm finding wild drag cams in roller cams. I don't want anything wild, just a tad more than a 340 grind or so. Thanks.
Re: Factory roller LA 360 aftermarket cams? [Re: da50r] #2219884
12/23/16 10:43 PM
12/23/16 10:43 PM
gregsdart Offline
gregsdart  Offline
There are, but pricy at about $400? I just bought one used, made by Bullet, for half that. EDIT: for a Magnum, but will go into an LA roller equipped motor. I understand they do have the right cores for your project, though.
I read about guys wanting to run a stock mechanical fuel pump in a 5.9 magnum, and the factory rollercam for the later LA360 fills the bill for that because it has the eccentric they have to have to run the pump. Just tossing that info out there in case you want to run a Magnum, with good heads. whistling
Re: Factory roller LA 360 aftermarket cams? [Re: da50r] #2219934
12/24/16 12:15 AM
12/24/16 12:15 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Factory roller LA 360 aftermarket cams? [Re: da50r] #2219935
12/24/16 12:18 AM
12/24/16 12:18 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Hughesengines
Comp Cams
Crane cams
