Road course/AutoX Fuel Cell #2219052
12/22/16 03:36 PM
12/22/16 03:36 PM
CJD AUTOMOTIVE Offline OP
Had this fuel cell made for the 'Cuda by Fuel Safe. It's an 18 gallon wedge cell for my road course/AutoX 'Cuda. It has a Holley VR2 mounted internally, which is basically two fuel pumps, with two -10 feeds. The pre filters mount in the tank as well, but are positioned directly under the fill plate for accessibility. You can see the two pick ups for the VR2 in the collector box, and the two smaller lift pumps on either side that continually fill the collector from the cell. This ensures the collector always has fuel for the the VR2 pump, regardless of G load. This also allows me to run just a few gallons of fuel for competition to help with the weight.
Pics are before the foam went in:
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Road course/AutoX Fuel Cell [Re: CJD AUTOMOTIVE] #2219160
12/22/16 06:15 PM
12/22/16 06:15 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is really really nice, dont even want to know what that set you back. Proper setups like that dont come cheap but peace of mind is priceless. I need to incorporate the wings that come off the front of the surge tank like yours. Thanks for sharing.
Mopar to the bone!!!
Re: Road course/AutoX Fuel Cell [Re: CJD AUTOMOTIVE] #2219331
12/22/16 11:33 PM
12/22/16 11:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I understand you car is a 9/10's+ set-up, and that pick up system is tough to beat, but you felt the Hydramat was not up to the task?
Re: Road course/AutoX Fuel Cell [Re: CJD AUTOMOTIVE] #2219481
12/23/16 10:42 AM
12/23/16 10:42 AM
moparx Online content
moparx  Online Content
what material is that ? nice set up internally.
beer
Re: Road course/AutoX Fuel Cell [Re: 72Swinger] #2219499
12/23/16 11:48 AM
12/23/16 11:48 AM
Yeah, a lot more than I wanted to spend....
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Road course/AutoX Fuel Cell [Re: jcc] #2219501
12/23/16 11:50 AM
12/23/16 11:50 AM
Wasn't me, I wanted to use it! When I talked to Fuel Safe and ATL, they both told me that, "It hadn't performed to there expectations", and suggested the lift pumps.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Road course/AutoX Fuel Cell [Re: moparx] #2219504
12/23/16 11:57 AM
12/23/16 11:57 AM
beer
I have no idea, probably some type of polymer bonded fabric that is a trade secret for the fuel cell companies.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Road course/AutoX Fuel Cell [Re: CJD AUTOMOTIVE] #2219554
12/23/16 01:10 PM
12/23/16 01:10 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think hydromat has a flow limit.
Re: Road course/AutoX Fuel Cell [Re: 72Swinger] #2219657
12/23/16 03:15 PM
12/23/16 03:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well technically everything does, and the reason the larger mats have multiple taps? Not sure there is limit to number of taps, nor what happens when suction exceeds flow capacity of the mat, Cavitation?
Re: Road course/AutoX Fuel Cell [Re: CJD AUTOMOTIVE] #2219800
12/23/16 07:40 PM
12/23/16 07:40 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Awesome setup!
Are those Aeromotive 340 pumps?
I was hesitant to get them as they are Made in China. I went with a Walbro instead.
I am sure you wont have any problems with 4 fuel pumps though!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Road course/AutoX Fuel Cell [Re: RylisPro] #2219852
12/23/16 09:39 PM
12/23/16 09:39 PM
Originally Posted By RylisPro
Awesome setup!
Thanks!
Yeah, Stealth pumps....made "offshore to Aeromotive spec by special Chinese workers". Not super happy about that, and didn't know until they were already installed, otherwise would have run Walboro's for sure. The suck parts is, I won't know if one quits....need to figure something out for that. Maybe a circuit light if the pump blows a fuse, but still won't tell me if it runs but doesn't pump.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: Road course/AutoX Fuel Cell [Re: CJD AUTOMOTIVE] #2219903
12/23/16 11:13 PM
12/23/16 11:13 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Are the pumps wired to the same power switch or wired to individual switches? Each pump should make a distinct noise on each side of the cell while the engine is not running.
I would just listen closely and if it doesn't sound normal, then inspect further.
I just have one pump in the middle of my cell so it will be easy to hear when it gives out haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Road course/AutoX Fuel Cell [Re: RylisPro] #2219907
12/23/16 11:24 PM
12/23/16 11:24 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Also if all the pumps are suppose to come on at the same time, wire them with separate connectors so you can unplug all but one, then plug in another while the first gets unplugged and so on, that way you can test each pump individually. Also number each pump and connector, so you know which pump isn't running when it's connector is the one that's plugged in, if there is one not working during the testing.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Road course/AutoX Fuel Cell [Re: CJD AUTOMOTIVE] #2222998
12/29/16 10:21 PM
12/29/16 10:21 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
man thats one sick fuel tank setup!!!! I ordered a hydramat that mounts on the bottom of the intank fuel pump for extra piece of mind, I already run a mopardude fuel tank with a 340 TRE intank fuel pump...
