Re: Weekly Bracket Racing
[Re: SILVER67]
#2218288
12/21/16 12:02 PM
12/21/16 12:02 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I would expect Dustin(Triple Threat) to answer this.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2218305
12/21/16 12:31 PM
12/21/16 12:31 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I would exptect Dustin(Triple Thread) to answer this. Dustin won so much he probably got sick of winning
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: SILVER67]
#2218387
12/21/16 02:42 PM
12/21/16 02:42 PM
Triple Threat
Renton Washington
So has anyone here been weekly bracket racing their G3? Such as a whole season? Round robin? Double classing?
Mike Yes Yes Yes I put roughly 150-175 runs on the car this past season, All 1/4 mile. Box, No Box, Super Street (10.90). Won like $5K roughly. Valve covers have been off once, Oil changed twice and a new idler arm from all the wheelies. Other than checking to make sure the bolts aren't falling out it's required no attention. I was double entered in late rounds and made five 1/4 mile runs in under an hour, back to back to back to back to back. I never had time to go to my trailer. That same day I put 17 runs on the car, and another 9 the following day. Add fuel, check air pressure in the slicks and charge the battery. Piece of cake. Best run has been 1.42, 6.42@107, 10.11@132 @3420#
[Re: Triple Threat]
#2218438
12/21/16 04:10 PM
12/21/16 04:10 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Mike Yes Yes Yes I put roughly 150-175 runs on the car this past season, All 1/4 mile. Box, No Box, Super Street (10.90). Won like $5K roughly. Valve covers have been off once, Oil changed twice and a new idler arm from all the wheelies. Other than checking to make sure the bolts aren't falling out it's required no attention. I was double entered in late rounds and made five 1/4 mile runs in under an hour, back to back to back to back to back. I never had time to go to my trailer. That same day I put 17 runs on the car, and another 9 the following day. Add fuel, check air pressure in the slicks and charge the battery. Piece of cake. Best run has been 1.42, 6.42@107, 10.11@132 @3420# So I'll ask you this! You had a small block R3 correct? Are you faster mph than you where with the R3?
[Re: MattW]
#2218515
12/21/16 06:57 PM
12/21/16 06:57 PM
Triple Threat
Renton Washington
So I'll ask you this! You had a small block R3 correct? Are you faster mph than you where with the R3? Yes, best run with the R3 was 129mph.
[Re: Dragula]
#2218518
12/21/16 06:58 PM
12/21/16 06:58 PM
Triple Threat
Renton Washington
I will say that is a really awesome season.....What is the weight of the car and gearing and what fuel? 3420# 727 with standard gear ratios 4.10 gear 30" slick E85
