Re: Mopar 4.5 bore blocks
[Re: fuseable]
#2218263
12/21/16 11:09 AM
12/21/16 11:09 AM
Posts: 52,972 Romeo MI
MR_P_BODY
When I was buying my mega block I was told by a mopar shop that the 4.5 block the bores were not round and would need to be finished... being a new block I had it line honed after I had it heat cycled
[Re: fuseable]
#2218371
12/21/16 02:21 PM
12/21/16 02:21 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I was wondering if anyone has ever used a finish bore block from Mopar? Like a 4.5 finish bore Hemi block. I would of course have it checked out by a Mopar orientated machine shop. Is it remotely possible the block would not need any work (like line bore, decking, re hone etc...) and could be ready to assemble with no work needed? NO chance
[Re: fuseable]
#2218522
12/21/16 07:02 PM
12/21/16 07:02 PM
Posts: 2,658 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I've bought 2 "ready to assemble" blocks from large racing engine building shops recently and I wouldn't call the bores "ready to go" on those either.
2011 Drag Pak Challenger
[Re: rickseeman]
#2219156
12/22/16 06:09 PM
12/22/16 06:09 PM
Posts: 3,396 Pa
Hot 340
Pa
How far undersize are the dowels? Stick a profilometer in the bores and see what it says. they measured .2435
[Re: rickseeman]
#2221823
12/27/16 08:41 PM
12/27/16 08:41 PM
Posts: 3,396 Pa
Hot 340
Pa
Some people think Mopar dowels are .250" but they aren't, they are .246 or 7. Stock 440 here measures even less than that with calipers. ordered a new block hardware kit the other day, well see what diameter the new dowels are.
[Re: fuseable]
#2221934
12/28/16 12:15 AM
12/28/16 12:15 AM
rickseeman
Stuttgart, Arkansas
What really makes me mad about the last one I bought is the bores are nearly .001" oversize. That's usually how much you have to remove for your first freshen up. So you've lost that because of their lack of quality. If it was a Chinese block you would understand because you didn't pay much for it.
[Re: Hot 340]
#2222060
12/28/16 03:31 AM
12/28/16 03:31 AM
Posts: 43,237 Bend,OR USA
Cab_Burge
Have a new hemi block here. I have noticed the dowel holes in the deck are undersize, which means stepping the diameter some on the head dowel for fitment. Havent checked everything, but cylinder bores are within a tenth of each other. On the cylinder bores did you check that with a torque plate? As far as within a tenth is that within 1/10 being round or taper ?
[Re: Cab_Burge]
#2222083
12/28/16 08:26 AM
12/28/16 08:26 AM
Posts: 3,396 Pa
Hot 340
Pa
Have a new hemi block here. I have noticed the dowel holes in the deck are undersize, which means stepping the diameter some on the head dowel for fitment. Havent checked everything, but cylinder bores are within a tenth of each other. On the cylinder bores did you check that with a torque plate? As far as within a tenth is that within 1/10 being round or taper ? From bore to bore. I checked in one axis with an inside mic (good ones) to check consistency from hole to hole. Not having a bore gauge handy or deck plate made up i didnt check roundness or taper. What would be the point without one...when i get some head bolts i can pull a head down and get readings from underneath.
[Re: Hot 340]
#2222242
12/28/16 04:09 PM
12/28/16 04:09 PM
Cab_Burge
Make sure the mains are torque to spec when checking the bores any time
[Re: Hot 340]
#2222806
12/29/16 03:07 PM
12/29/16 03:07 PM
Posts: 3,396 Pa
Hot 340
Pa
Have a new hemi block here. I have noticed the dowel holes in the deck are undersize, which means stepping the diameter some on the head dowel for fitment.. Got the block hardware kit today. The dowel pins in the kit are .244 diameter, and the tapped right in the block. So the machining on the holes is *LEGIT*... As Rick stated, some people think the dowels are *SUPPOSED* to be .250, and I was one of them.
[Re: Hot 340]
#2222816
12/29/16 03:17 PM
12/29/16 03:17 PM
MR_P_BODY
If you have any deck or head work done make sure the dowels arent too long.. I always set the heads on without a gasket to see if they lay flat on the block.. I had one set that didnt.. was hanging up on the dowels
