Strange 12 Bolt drop out centre section #2218204
12/21/16 03:01 AM
12/21/16 03:01 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Has anyone used one of the Strange Eng 12 bolt centres that drop into a 9" housing? I've only really seen them in Comp eliminator cars, just curious if anyone has used one?
Alan Jones
Re: Strange 12 Bolt drop out centre section [Re: LA360] #2218210
12/21/16 03:33 AM
12/21/16 03:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You have to be kidding.. these people only know
a dana... that 12 bolt is suppose to be a good
unit and to have it as a drop out.. perfect
wave
Re: Strange 12 Bolt drop out centre section [Re: LA360] #2218224
12/21/16 05:07 AM
12/21/16 05:07 AM
Cab_Burge Online work
Cab_Burge  Online Work
The NHRA SS/AH cars use to run them until they started making their cars powerful enough to break them on almost every run shruggy work scope
I'm not sure what they use now confused shruggy
Re: Strange 12 Bolt drop out centre section [Re: LA360] #2218230
12/21/16 06:04 AM
12/21/16 06:04 AM
Guitar Jones Offline
Comp cars are a different breed. Most are small displacement high winding combinations to keep the weight down. They don't need the brute strength of a 9" or 9.5" rear so the 12 bolt offers less drag, less weight and many gear ratio options.
Re: Strange 12 Bolt drop out centre section [Re: LA360] #2218232
12/21/16 06:46 AM
12/21/16 06:46 AM
kansas
farmboy Offline
farmboy  Offline
kansas
I have had one in my 3600 lb. Challenger for 10 years. 4.30 pro gear. Lots of 1.30 launches. Has run some 9.20's. Currently driving on the street on drag radials, but can still knock out a 1.40 on a good track. It's been perfect.
Re: Strange 12 Bolt drop out centre section [Re: MR_P_BODY] #2218824
12/22/16 05:55 AM
12/22/16 05:55 AM
LA360 Offline OP
LA360  Offline OP
wave
It was a long shot Mike, plus a bit of a pot stir!
Alan Jones
