SB ductile iron rockets?
#2217415
12/20/16 12:59 AM
12/20/16 12:59 AM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
Looking at a set for sale on here. How much lift/spring pressure can they handle? Not 100% sure, but they may be 273 rockers. Thanks!
Re: SB ductile iron rockets?
[Re: BradH]
#2217427
12/20/16 01:10 AM
12/20/16 01:10 AM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Who'd want to launch one of those??? I've launched mice, fireworks/bombs of all kinds, propaganda notes, marijuana seeds....a rocker? No problem.
[Re: slantzilla]
#2217456
12/20/16 01:38 AM
12/20/16 01:38 AM
Posts: 300 Willow Spring
dagohman
Willow Spring
I've used 273 adjustable arms on 2 different 340's. One had a 525/305 comp hyd. cam, The other was Mopar 528 solid. I had double springs, cant remember the pressure, etc. I've heard of people using them on larger camshafts. I haven't launched any though
[Re: BradH]
#2217569
12/20/16 05:51 AM
12/20/16 05:51 AM
slantzilla
Park Forest, IL
Who'd want to launch one of those??? Posted from my phone. Fingers are bigger than the keyboard.
[Re: dagohman]
#2217700
12/20/16 01:16 PM
12/20/16 01:16 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
I ran 273 iron rockers on my J headed 340 with a 557 lift mech. cam and iron ones on my W2 heads with a 627 lift roller cam then a 590 lift mechanical cam and never broke one or had a problem after many years and runs only replacing one adjuster once. Sorry dont remembe the spring pressure.
[Re: slantzilla]
#2217772
12/20/16 02:44 PM
12/20/16 02:44 PM
Posts: 7,506 Az
Crizila
Az
With open pressures around the 375 lb range and lift around .550, I wouldn't sweat it Dennis. Think I would look at after market stuff if I were going over 400 / .600. I ran them for a while in 67 in a warmed up 273 with no problems. Never check accuracy though?
Fastest 300
[Re: 11secdart]
#2217802
12/20/16 03:21 PM
12/20/16 03:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran 273 iron rockers on my J headed 340 with a 557 lift mech. cam and iron ones on my W2 heads with a 627 lift roller cam then a 590 lift mechanical cam and never broke one or had a problem after many years and runs only replacing one adjuster once. Sorry dont remembe the spring pressure. I never knew they made a offset with that much offset to run them on a W-2 head
[Re: MR_P_BODY]
#2217896
12/20/16 05:47 PM
12/20/16 05:47 PM
Posts: 4,457 Washington
madscientist
Washington
I ran 273 iron rockers on my J headed 340 with a 557 lift mech. cam and iron ones on my W2 heads with a 627 lift roller cam then a 590 lift mechanical cam and never broke one or had a problem after many years and runs only replacing one adjuster once. Sorry dont remembe the spring pressure. I never knew they made a offset with that much offset to run them on a W-2 head I assumed he was talking about the iron rockers for W-2 heads. Made of the same [censored] as the Isky and Crane rockers.
[Re: mkdart]
#2218245
12/21/16 09:50 AM
12/21/16 09:50 AM
11secdart
new jersey usa
Yes two different sets of rockers , 273 on the J heads and the W2 heads had a set of offset W2 iron rockers
