Re: converter selection, need some pointers
[Re: Chassisman]
#2219205
12/22/16 08:00 PM
12/22/16 08:00 PM
Thumperdart
State of confusion
Kris at Continental Converter is/has passed the business on but that's who I've used for many years and never sent one back for an adjustment............ He's sending a lot of stuff to Dice Performance Converters.... LANCASTER DOM !!!!!! Like what and since when?
[Re: gregsdart]
#2219291
12/22/16 10:46 PM
12/22/16 10:46 PM
dartman366
Mt. Vernon, Ohio
Just a guess on what will please you for driveability; it sounds like a stock configuration 10 3/4 Mopar converter, set up to act just like a factory original yet be built for the abuse a 540 can deliver is what will work well for you. I used exactly that converter behind a 535 cube wedge with a 590 cam in it, and it stalled plenty high yet was tight enough to not flash a lot higher at a light throttle application. If you take the K factor into consideration, it will give you an idea of what it will do in the car. Those converters were used behind 340s ,383s, and street hemis I believe. The stall behind a street hemi was about 2800 from what I have read, and 2400 behind a 340. That same converter stalled quite a bit higher behind my 535, like mid 3,000 or more. A couple of things make me think this might be the right path for you. You want street drivability over ultimate performance for one. The other is street traction. A motor like that ought to be able to fry the tires at low speeds anyway, so a high stall loose converter just isn't needed much there. GregI hope you are not inplying that this car is street driven as it hasn't seen the highway or city street in over 20 years, it is a dedicated bracket car, altho I would just love to take a blast thru the neighborhood just once and pizz off the neighbor's down the street.
[Re: dartman366]
#2219315
12/22/16 11:19 PM
12/22/16 11:19 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Just a guess on what will please you for driveability; it sounds like a stock configuration 10 3/4 Mopar converter, set up to act just like a factory original yet be built for the abuse a 540 can deliver is what will work well for you. I used exactly that converter behind a 535 cube wedge with a 590 cam in it, and it stalled plenty high yet was tight enough to not flash a lot higher at a light throttle application. If you take the K factor into consideration, it will give you an idea of what it will do in the car. Those converters were used behind 340s ,383s, and street hemis I believe. The stall behind a street hemi was about 2800 from what I have read, and 2400 behind a 340. That same converter stalled quite a bit higher behind my 535, like mid 3,000 or more. A couple of things make me think this might be the right path for you. You want street drivability over ultimate performance for one. The other is street traction. A motor like that ought to be able to fry the tires at low speeds anyway, so a high stall loose converter just isn't needed much there. GregI hope you are not inplying that this car is street driven as it hasn't seen the highway or city street in over 20 years, it is a dedicated bracket car, altho I would just love to take a blast thru the neighborhood just once and pizz off the neighbor's down the street. I noticed this, think he meant to post in the Other vert thread, that's looking for a more street friendly vert.
[Re: dartman366]
#2219608
12/23/16 02:01 PM
12/23/16 02:01 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I noticed this, think he meant to post in the Other vert thread, that's looking for a more street friendly vert. I thought the same thing. It's either that or too much/too little coffee.
[Re: dartman366]
#2219614
12/23/16 02:09 PM
12/23/16 02:09 PM
fast68plymouth
So. Burlington, Vt.
While I haven't purchased too many converters for myself, I have helped many many people get their combos sorted out through the years.
I'd be surprised if out of all those combos there were more than 20 where the converter seemed close enough on the first shot where it got left in the car. Most end up going back at least once. Several ended up going somewhere other than where they where made to get "fixed"...... Some just got replaced with something else.
I'm always amazed at how you can give the exact same info, and request the same stall to two different converter shops, and get back two completely different performing units, with huge differences in stall....... And sometimes neither is what you asked for.
Somewhere on this thread someone mentioned how many times a converter shop will try and give you what they think is what you should have, regardless of what you ask for...... Because they know better than you.
My feeling is......... Just give me what I ask for..... Even if it's wrong and will make the car slower. At least then I'll learn something.
[Re: fast68plymouth]
#2219676
12/23/16 03:51 PM
12/23/16 03:51 PM
dartman366
Mt. Vernon, Ohio
My feeling is......... Just give me what I ask for..... Even if it's wrong and will make the car slower. At least then I'll learn something. You are correct Dwayne, I have known guy's that have gone thru the same thing, some times some thing's seem to be a crap shoot, I had forgotten that I do have a TCI streetfighter converter part#142200 that I had purchased from Chapper a couple of years ago that need's a starter ring gear replaced,, may take it to Quickdraw and get it fixed and have him evaluate it and see if he can do anything with it to make it work for me, if not then I will go with a new build.
[Re: dartman366]
#2219871
12/23/16 10:13 PM
12/23/16 10:13 PM
Posts: 1,115 Usa
A39Coronet
Usa
Everyone is going to suggest who they use. Turbo Action, ATI, etc all the big name places are going to give you pretty much the same thing. Call them, tell them what you have and what you want to do, and let them build you a unit. It's simple as that.
If your local guy has Wallies and bracket race wins under his belt, go with them. If not, don't. There is no benefit to going local when it cost $75 to ship a converter anywhere in the country, and the difference can be a round win.
[Re: savoy64]
#2219889
12/23/16 10:51 PM
12/23/16 10:51 PM
Posts: 1,115 Usa
A39Coronet
Usa
my friend larry owned a torque converter rebuilding shop---he said most of the catalog converters are loose (inefficient) Bracket racing converters are normally set up on the loose side so you can drive the stripe easier. The looser the converter, the smaller incremental loss in ET when you rip the throttle driving the stripe. They don't pay anymore more to the purse if you're setting ET records.
[Re: dartman366]
#2219891
12/23/16 10:53 PM
12/23/16 10:53 PM
Posts: 10,035 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Just a guess on what will please you for driveability; it sounds like a stock configuration 10 3/4 Mopar converter, set up to act just like a factory original yet be built for the abuse a 540 can deliver is what will work well for you. I used exactly that converter behind a 535 cube wedge with a 590 cam in it, and it stalled plenty high yet was tight enough to not flash a lot higher at a light throttle application. If you take the K factor into consideration, it will give you an idea of what it will do in the car. Those converters were used behind 340s ,383s, and street hemis I believe. The stall behind a street hemi was about 2800 from what I have read, and 2400 behind a 340. That same converter stalled quite a bit higher behind my 535, like mid 3,000 or more. A couple of things make me think this might be the right path for you. You want street drivability over ultimate performance for one. The other is street traction. A motor like that ought to be able to fry the tires at low speeds anyway, so a high stall loose converter just isn't needed much there. GregI hope you are not inplying that this car is street driven as it hasn't seen the highway or city street in over 20 years, it is a dedicated bracket car, altho I would just love to take a blast thru the neighborhood just once and pizz off the neighbor's down the street. oops. Totally blew that one. I must have read another thread and somehow answered yours! Edit again; that was Hemiragtops post I read,,, I'm going to take a nap,,,,
[Re: dartman366]
#2227738
01/05/17 01:40 PM
01/05/17 01:40 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Lenny's has been behind motors ranging from 446-512 in my Arrow and has been flawless. This is without a dyno sheet so I'm sure there might be more in it. He picked up 5 mph in the original Hughes the first time he touched it.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#2228241
01/05/17 11:12 PM
01/05/17 11:12 PM
dartman366
Mt. Vernon, Ohio
Lenny's has been behind motors ranging from 446-512 in my Arrow and has been flawless. This is without a dyno sheet so I'm sure there might be more in it. He picked up 5 mph in the original Hughes the first time he touched it. he is on my short list.
[Re: dartman366]
#2230213
01/08/17 06:50 PM
01/08/17 06:50 PM
dartman366
Mt. Vernon, Ohio
Lenny's has been behind motors ranging from 446-512 in my Arrow and has been flawless. This is without a dyno sheet so I'm sure there might be more in it. He picked up 5 mph in the original Hughes the first time he touched it. he is on my short list. one day after submitting my tech sheet Lenny call's and we discuss my need's,, two weeks after I submit my tech sheet to TCI I still have no response,,,guess who is going to get my bussiness.
[Re: dartman366]
#2230443
01/08/17 10:50 PM
01/08/17 10:50 PM
Posts: 1,030 ohio
67mprfan
ohio
Lenny's has been behind motors ranging from 446-512 in my Arrow and has been flawless. This is without a dyno sheet so I'm sure there might be more in it. He picked up 5 mph in the original Hughes the first time he touched it. he is on my short list. one day after submitting my tech sheet Lenny call's and we discuss my need's,, two weeks after I submit my tech sheet to TCI I still have no response,,,guess who is going to get my bussiness. I've been happy with Lenny's product
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Eric]
#2230520
01/09/17 12:29 AM
01/09/17 12:29 AM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
Lenny's has been behind motors ranging from 446-512 in my Arrow and has been flawless. This is without a dyno sheet so I'm sure there might be more in it. He picked up 5 mph in the original Hughes the first time he touched it. I had Lenny build a 8" converter for my 408 after I killed my 9.5" $450 Edge racing Converter. It never 60' within .1 of the Edge and .2 in the 1/8. After building and dynoing my 434 I called Lenny and talked about my converter. He said it should be good, so I tried it, 18% slip in the 1/8. So I call him back and he says it's to loose and to send it back. He tightened it up 500 rpms (at almost $275) 5100 from 5600. I ran a best of 1.38 several times with the 408 and a $450 9.5" Edge converter. After adding 100+ HP and probably that much torgue, plus spending over $1500 on a converter from Ultimate I have ran a best 60' of 1.44. I'll look elsewhere for my converters.
