Dakota lift kit question #2216990
12/19/16 02:35 PM
12/19/16 02:35 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
I was thinking of installing a 2" lift kit on my 2004 Dakota 4x4. The kit comes with the levers for the torsion bars. Can't I just crank up my front torsion bar bolts to get the 2" lift for the front and not have to bother installing the levers in the kit?
Re: Dakota lift kit question [Re: 340Scamp] #2217020
12/19/16 03:23 PM
12/19/16 03:23 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
I think that you will lose suspension travel to the unloaded state by doing that. The kit will keep the travel you have now.
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Dakota lift kit question [Re: 300rag] #2217070
12/19/16 04:43 PM
12/19/16 04:43 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Agreed.
It will also ride like garbage if you crank the bars up that much. Very stiff, steering will be crap whenever you hit a bump, etc...the kit includes levelers for a reason. Use 'em.
Earning every penny of that moderator paycheck.
DBAP
Re: Dakota lift kit question [Re: 340Scamp] #2217077
12/19/16 04:55 PM
12/19/16 04:55 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
If I use the levers in the kit will I need to have a front end alignment?
Re: Dakota lift kit question [Re: 340Scamp] #2217476
12/20/16 02:18 AM
12/20/16 02:18 AM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
It would be wise to have an alignment done any time you modify the suspension.
Peter
'19 Durango R/T
