Page 1 of 3 1 2 3
Spectra fuel tanks? #2216872
12/19/16 11:06 AM
12/19/16 11:06 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Does anyone have any experience with these tanks? Are they any good? I dont want to have to worry about corrosion. http://www.spectrapremium.com/products/fuel_tank.html
Re: Spectra fuel tanks? [Re: UCUDANT] #2216883
12/19/16 11:44 AM
12/19/16 11:44 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Spectra is all I use 4 cars now and look at Rockauto for a good price if they stock the one you need
1969 Hemi Roadrunner 2nd owner
Re: Spectra fuel tanks? [Re: 69hemibeep] #2216891
12/19/16 11:59 AM
12/19/16 11:59 AM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I've installed 2 in both my Challengers with good results.
I found the best price for me was off E-bay with free shipping.
Fit and finish was excellent, I would buy another if needed.
Now I've heard the aftermarket sending units are a different story.....
Re: Spectra fuel tanks? [Re: UCUDANT] #2216895
12/19/16 12:10 PM
12/19/16 12:10 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Spectra is all I use. They always fit well and have the correct nitern finish. There are some other brands that simply paint the tank silver.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Spectra fuel tanks? [Re: mopargem] #2216919
12/19/16 01:10 PM
12/19/16 01:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree X 4
Re: Spectra fuel tanks? [Re: UCUDANT] #2216963
12/19/16 02:03 PM
12/19/16 02:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Used them at work on newer stuff.Always worked good.Rocky
Chrysler Firepower
Re: Spectra fuel tanks? [Re: therocks] #2216980
12/19/16 02:21 PM
12/19/16 02:21 PM
Add me to the list of satisfied purchasers. (2 of em). One was even from the infamous Frankie Mitchell (God rest his soul).
Re: Spectra fuel tanks? [Re: UCUDANT] #2217018
12/19/16 03:22 PM
12/19/16 03:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
While I've used the Spectra tanks and sending units with success, and they fit nicely, I'd be more apt to try out the Stainless Steel tanks now offered thru Classic Ind, just about the same price to avoid corrosion issues
Re: Spectra fuel tanks? [Re: UCUDANT] #2217202
12/19/16 07:58 PM
12/19/16 07:58 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks to all, I checked Rock auto and they were 160 plus shipping, I had already been watching them on ebay over the last year so I went with what I had originally been after, $125 with free shipping ... and that's done.
Thanks again
Re: Spectra fuel tanks? [Re: UCUDANT] #2217208
12/19/16 08:06 PM
12/19/16 08:06 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I have the Spectra (CR8CFI) with the in tank EFI pump and their sender. They all work as advertised.
Craig
Re: Spectra fuel tanks? [Re: UCUDANT] #2217217
12/19/16 08:19 PM
12/19/16 08:19 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thats good to know, I am upgrading to fuel injection and electing to install a new tank. I will be using Fi Tech's remote sump/pump system at least for now.
Re: Spectra fuel tanks? [Re: UCUDANT] #2217240
12/19/16 09:01 PM
12/19/16 09:01 PM
The real problem is gonna be finding a sender that reads accurate to go along with it
Re: Spectra fuel tanks? [Re: UCUDANT] #2217254
12/19/16 09:27 PM
12/19/16 09:27 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I hope one day they will make the 76 77 F body tank.
Re: Spectra fuel tanks? [Re: mopars4ever] #2217260
12/19/16 09:34 PM
12/19/16 09:34 PM
georgia
moparpro Offline
moparpro  Offline
georgia
i had to adjust my fuel sending unit to read pretty close to accurate full levels,all sending units has to be adjusted to read full,if not everyone you buy will go way past full mark.
Re: Spectra fuel tanks? [Re: moparpro] #2217272
12/19/16 09:47 PM
12/19/16 09:47 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
How bend the rod?
Re: Spectra fuel tanks? [Re: mopargem] #2217301
12/19/16 10:43 PM
12/19/16 10:43 PM
I like em accurate on the low end so when the needle is dead on the E line I have just enough gas left to hit a station
Re: Spectra fuel tanks? [Re: UCUDANT] #2217624
12/20/16 11:30 AM
12/20/16 11:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I bought a 3/8 SS sender off Ebay like 10 years ago.It works almost as good as the OE one did in my 65.Its off a bit but not a lot.Just like the one was when I got the car in 69.Rocky
Chrysler Firepower
Re: Spectra fuel tanks? [Re: mopargem] #2218033
12/20/16 10:27 PM
12/20/16 10:27 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
How bend the rod?
Yes, bend the rod and possibly the stops at either end if needed...I usually hook up the sending unit under the car{out of the tank} and run it through it's range of motion and watch the fuel gauge..As other's have stated you want the low end to be somewhat accurate if you miss it make sure you have a few gallons in the tank at empty not run out before... twocents
Re: Spectra fuel tanks? [Re: RapidRobert] #2218481
12/21/16 05:54 PM
12/21/16 05:54 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The sender on my Spectra tank reads 70.2 ohms on empty and 8.1 ohms on full. It is enough to send the gauge to Full and it read empty when installed. It holds 17.83 gallons when full. That includes the filler neck. The Mopar senders that I have seen over the years were 70 ohms on empty and 10 ohms on full so this one is pretty close to dead nuts.
I have only had two fills since install. I am trying to log how much it takes to fill it at different gauge levels. That will have to wait a few months to nicer Rocky Mountain weather.
Craig
Re: Spectra fuel tanks? [Re: UCUDANT] #2218575
12/21/16 08:42 PM
12/21/16 08:42 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have a Spectra tank in my Demon (It's a Ford Mustang/Falcon tank) and I used the supplied sending unit. Had to bend the tabs a bit to get it accurate with a Stewart Warner gas gauge,but not any problem.
Nautilus Racing-
Page 1 of 3 1 2 3
