Page 2 of 3 1 2 3
Re: Strong B-block bottom end for max hp effort [Re: slantzilla] #2216310
12/18/16 04:18 PM
12/18/16 04:18 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
High numbers sell ragazines. Rag a zines.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Strong B-block bottom end for max hp effort [Re: pittsburghracer] #2216321
12/18/16 04:29 PM
12/18/16 04:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I know.. everyone thinks that if I do that
I will end up with the same numbers.... NOT
wave
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2216419
12/18/16 06:48 PM
12/18/16 06:48 PM
AndyF Offline
AndyF  Offline
Well a super rigid billet dry sump pan might be an option. This one has 1/2 inch thick rails to help tie the bottom end together. I'd also probably use a cross bolt conversion if your block isn't cross bolted to start with.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2216420
12/18/16 06:51 PM
12/18/16 06:51 PM
AndyF Offline
AndyF  Offline
The low deck 512 that I have in my street car uses a 230 block that has been cross bolted. We also opened up the mains to the larger 440 bearing size. Here is a picture:
Re: Strong B-block bottom end for max hp effort [Re: AndyF] #2216426
12/18/16 06:59 PM
12/18/16 06:59 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Andy is that a stock block? This is the first I have ever seen this on a stock block. shruggy how's it holding up for ya.?
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2216442
12/18/16 07:28 PM
12/18/16 07:28 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Those look like Pro-Gram caps. The install of those requires cutting on the already weak main web supports. That's why they are not hugely popular.
If I was doing the OPs build, it would consist of a half fill 440 block, alum caps, center weighted crank, as light a bobweight as I could get.............and prayer
Re: Strong B-block bottom end for max hp effort [Re: racerx] #2216514
12/18/16 08:57 PM
12/18/16 08:57 PM
AndyF Offline
AndyF  Offline
Yep, it is a 230 cold weather block with all the mods. Even has roller cam bearings. Not sure what to say about it holding up. The engine was built about 10 years ago but it doesn't have much run time on it. It is in my '65 Coronet which mostly just sits in the shop so it doesn't have many miles on it.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2216520
12/18/16 09:03 PM
12/18/16 09:03 PM
AndyF Offline
AndyF  Offline
Even if I did drive it a ton I doubt I'd hurt the bottom end seeing how the engine has manifolds on it. Yep, cross bolted mains, roller cam bearings and manifolds - not exactly the best planned out combo........
Re: Strong B-block bottom end for max hp effort [Re: AndyF] #2216563
12/18/16 09:35 PM
12/18/16 09:35 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
bet it's a hoot to drive tho. up
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2216625
12/18/16 10:26 PM
12/18/16 10:26 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
HAHAHA Dayum Andy, mad scientist stuff you do kills me. Paranoia of failure can make one do some ridiculous stuff at times.
Mopar to the bone!!!
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2216955
12/19/16 01:58 PM
12/19/16 01:58 PM
warren, mich.
dwayne welder Offline
warren, mich.
Andy what kind of adapter you have on the oil pump? And do you make that or who does. Thanks
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2216972
12/19/16 02:11 PM
12/19/16 02:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Says "AR Engineering" on it, so I'd say he made it.
Re: Strong B-block bottom end for max hp effort [Re: fast68plymouth] #2217089
12/19/16 05:11 PM
12/19/16 05:11 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Pretty safe bet eh Dwayne!
How are you my friend?
Don
Re: Strong B-block bottom end for max hp effort [Re: dwayne welder] #2217195
12/19/16 07:45 PM
12/19/16 07:45 PM
AndyF Offline
AndyF  Offline
That is a one of one custom part. It is basically an adapter for a remote filter and/or cooler but just without the internal 90 degree bends that all of the other adapters have.
I was going to sell it as a product but decided it was too expensive to build in qty so I scrapped it. I use it all the time though, especially on the dyno.
Re: Strong B-block bottom end for max hp effort [Re: AndyF] #2223519
12/30/16 06:38 PM
12/30/16 06:38 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Who Makes that piece Andy? It's a beauty, I didn't see it on your site.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2223536
12/30/16 06:54 PM
12/30/16 06:54 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I am guessing that's made by Dailey Engineering, but could be wrong. That just looks life stuff he makes
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2223557
12/30/16 07:19 PM
12/30/16 07:19 PM
AndyF Offline
AndyF  Offline
I made the dry sump pan myself.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2223575
12/30/16 07:59 PM
12/30/16 07:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the purpose of the girdle is to prevent the pan rail and caps from moving, mild steel of the same thickness is far better than any aluminum.
Boffin Emeritus
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2223635
12/30/16 09:48 PM
12/30/16 09:48 PM
AndyF Offline
AndyF  Offline
True, but I don't think I'd be able to pick up the pan if it was made from steel. It is already super heavy in aluminum.
Re: Strong B-block bottom end for max hp effort [Re: Lifsgrt] #2223795
12/31/16 01:48 AM
12/31/16 01:48 AM
gregsdart Offline
gregsdart  Offline
I would start with a good center weighted, lightened to the max crank. I would stay with the small BB main bearing, and consider a small rod bearing like a 2.100. You can then get a fairly light custom rod to fit your combo. The center weight crank loads the main saddles more evenly, and I saw it eliminate cap walk on my cross bolted Megablock when I switched to one.
As far as the rest of the shortblock, definitely use a partial fill, and a girdle with steel main caps would be on my list. I would also sneak up on the tuneup, starting conservatively, and never look for that last hp.
Page 2 of 3 1 2 3
