Page 2 of 3 1 2 3
Re: Anyone running Ried case & bell th400 small block patern? [Re: junior636] #2213638
12/14/16 12:02 AM
12/14/16 12:02 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Two months ago I had what you needed and could have done that. Just sold the sbm bell last week.
Sorry
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2213723
12/14/16 02:16 AM
12/14/16 02:16 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
If you want it built Lenny at extreme automatics in cincy is close and has a good rep.
I used a Jw bell and a stock case. Built it myself. Th400's are fairly easy to garage build. Personally I like them a lot more than 727s. BOP cores are cheap and parts are readily available.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Anyone running Ried case & bell th400 small block patern? [Re: junior636] #2213752
12/14/16 03:45 AM
12/14/16 03:45 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Just out of curiousity, does anyone have any of the dimensions for the Reid or ATI bells? Just curious as to what the height is flange to flange? Anyone have CAD for the trans bolt pattern?
Alan Jones
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2213817
12/14/16 12:05 PM
12/14/16 12:05 PM
Indianapolis In. usa
Quickrunner Offline OP
Looked at the Ried stuff at PRI. Very nice indeed! and the small block/Gen3 bell has provisions for starter on ether side, I dont thing the ATI bell does. I am going with this Ried setup with a Gear Vendor OD on the back for my build.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2213832
12/14/16 12:47 PM
12/14/16 12:47 PM
michigan
junior636 Offline
junior636  Offline
michigan
If anyone has a small block or gen 3 hemi to TH400 bellhousing let me know. Looks like they may be on back order at JW.
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2213839
12/14/16 01:02 PM
12/14/16 01:02 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
How well does a TH400 with SFI case fit in an A-Body?
Bill
Re: Anyone running Ried case & bell th400 small block patern? [Re: LA360] #2213887
12/14/16 02:47 PM
12/14/16 02:47 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Allen, the ATI is 1/4" taller than most Reid mopar bells. The very first Reids were the same as ATI. Reid shortened theirs after pte ious JW customers complained about the e,tra 1/4".
Re: Anyone running Ried case & bell th400 small block patern? [Re: junior636] #2213889
12/14/16 02:50 PM
12/14/16 02:50 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
BTE makes a Reid bell with a T400 pump adapter for those whos budget doesnt allow the Reid case.
I personally hate bolting bells through the pump bolts. The JW solution was the only way for years. Now the flanged cases are available and light years ahead.
Re: Anyone running Ried case & bell th400 small block patern? [Re: Leon441] #2213954
12/14/16 05:08 PM
12/14/16 05:08 PM
michigan
junior636 Offline
junior636  Offline
michigan
Yeah, I would like to keep my stock case TH400. No money for an upgrade right now....
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2216359
12/18/16 05:29 PM
12/18/16 05:29 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Bill
Re: Anyone running Ried case & bell th400 small block patern? [Re: 340Cuda] #2217775
12/20/16 02:45 PM
12/20/16 02:45 PM
Bill
Im going to find out after the first of the year, going to order a Reid case & bell. Initial thoughts are floor is going to need major mods farther back. 400 is longer and fatter towards tail shaft. New trans cross member will need to be fabed as well
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2217788
12/20/16 03:01 PM
12/20/16 03:01 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
For what its worth, Lenny at Extreme Automatics built me One of his Stage 2 200R4's for my Magnum based 408 that uses a Reid SFI housing. I'm only putting out about 510hp at the crank. His Stage 2 is said to hold 750hp. He has a Stage 3 that is said to hold over 1000hp.
I run a Precision of New Hampton 3600 stall lock-up converter with the 3 carbon fiber clutch pack. It makes the car feel like its a 5 speed automatic. I have a 3.91 gear set and 28 inch tall Nittos. The car tachs 2500 rpm at 80 mph, and I beat a Hellcat in a flag drop 1/4 mile drag race. This trans torque converter combo helped make that possible. I had him by 3 car lengths at the 1/8th and held him to a nose at the finish. He was charging hard at the end. I'm sure another driver would have had me, but not out of the hole on street tires.
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2217791
12/20/16 03:03 PM
12/20/16 03:03 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I mocked one up in my Valiant. Ati bell,stock case. I have a 4 speed hump in the floor also. To get it in at the stock drive angle,I had to trim the torsion bar crossmember where it loops up to support the driveshaft tunnel. Just fit and no room for a shield. The Reid or Ati case should fit with some trimming and selective denting.
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2217897
12/20/16 05:51 PM
12/20/16 05:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
For what its worth, Lenny at Extreme Automatics built me One of his Stage 2 200R4's for my Magnum based 408.....
Very cool up
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2218338
12/21/16 01:32 PM
12/21/16 01:32 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Thanks, please keep us posted!
Bill
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2218433
12/21/16 04:04 PM
12/21/16 04:04 PM
USA
hudsonhornet7x Offline
USA
How good/bad would a th400 fit into a 68 B body? I have a gen III hemi and would like to run a th400. Thanks
Re: Anyone running Ried case & bell th400 small block patern? [Re: hudsonhornet7x] #2218552
12/21/16 08:06 PM
12/21/16 08:06 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
All these guys want to run a GM transmission in a Mopar!!!!!
Blasphemy !!!!
This is not MOPARTS AT ALL !!!!!!
Where's Monty!!!!
Re: Anyone running Ried case & bell th400 small block patern? [Re: MattW] #2218608
12/21/16 09:45 PM
12/21/16 09:45 PM
USA
USA
Blasphemy !!!!
Where's Monty!!!!
Probably shouldn't say anything about my ls lol.
Re: Anyone running Ried case & bell th400 small block patern? [Re: MattW] #2218886
12/22/16 12:09 PM
12/22/16 12:09 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Blasphemy !!!!
Where's Monty!!!!
Hey, they come in some Drag Packs. I forget the euphemism, something like "Racing Automatic Transmission"
Bill
Re: Anyone running Ried case & bell th400 small block patern? [Re: Quickrunner] #2218896
12/22/16 12:22 PM
12/22/16 12:22 PM
At the level I am shooting for I will have less money in a better transmission with an SFI case & bell that will need no shields. Better converter choices as well.
Page 2 of 3 1 2 3
