older 50's V-8's Need help Indentifing #221610
02/11/09 08:57 PM
02/11/09 08:57 PM
findingfish Offline OP
I have a V-8 from the 50's era It doesn't have the hemi heads. The only place I found numbers on the block are on the decking by the valley pan that's under the intake. Numbers are placed at the front of the block by waterpump. Numbers start with VT388-I4997. Is there any other place on the engine where I need to look
Re: older 50's V-8's Need help Indentifing [Re: findingfish] #221611
02/11/09 10:28 PM
02/11/09 10:28 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Re: older 50's V-8's Need help Indentifing [Re: earlybee] #221612
02/12/09 12:32 AM
02/12/09 12:32 AM
Thanks you help a lot. Chuck W.
