Re: Strong B-block bottom end for max hp effort
[Re: slantzilla]
#2216310
12/18/16 04:18 PM
12/18/16 04:18 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
High numbers sell ragazines. Rag a zines.
[Re: pittsburghracer]
#2216321
12/18/16 04:29 PM
12/18/16 04:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
High numbers sell ragazines. Rag a zines. Yeah I know.. everyone thinks that if I do that I will end up with the same numbers.... NOT
[Re: Lifsgrt]
#2216420
12/18/16 06:51 PM
12/18/16 06:51 PM
Posts: 31,061 Oregon
AndyF
The low deck 512 that I have in my street car uses a 230 block that has been cross bolted. We also opened up the mains to the larger 440 bearing size. Here is a picture:
[Re: racerx]
#2216514
12/18/16 08:57 PM
12/18/16 08:57 PM
AndyF
Andy is that a stock block? This is the first I have ever seen this on a stock block. how's it holding up for ya.? Yep, it is a 230 cold weather block with all the mods. Even has roller cam bearings. Not sure what to say about it holding up. The engine was built about 10 years ago but it doesn't have much run time on it. It is in my '65 Coronet which mostly just sits in the shop so it doesn't have many miles on it.
[Re: Lifsgrt]
#2216520
12/18/16 09:03 PM
12/18/16 09:03 PM
AndyF
Even if I did drive it a ton I doubt I'd hurt the bottom end seeing how the engine has manifolds on it. Yep, cross bolted mains, roller cam bearings and manifolds - not exactly the best planned out combo........
[Re: AndyF]
#2216563
12/18/16 09:35 PM
12/18/16 09:35 PM
dartman366
Mt. Vernon, Ohio
Even if I did drive it a ton I doubt I'd hurt the bottom end seeing how the engine has manifolds on it. Yep, cross bolted mains, roller cam bearings and manifolds - not exactly the best planned out combo........ bet it's a hoot to drive tho.
[Re: Lifsgrt]
#2216625
12/18/16 10:26 PM
12/18/16 10:26 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
HAHAHA Dayum Andy, mad scientist stuff you do kills me. Paranoia of failure can make one do some ridiculous stuff at times.
Mopar to the bone!!!
[Re: Lifsgrt]
#2216972
12/19/16 02:11 PM
12/19/16 02:11 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Says "AR Engineering" on it, so I'd say he made it.
[Re: fast68plymouth]
#2217089
12/19/16 05:11 PM
12/19/16 05:11 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Says "AR Engineering" on it, so I'd say he made it. Pretty safe bet eh Dwayne! How are you my friend? Don
[Re: dwayne welder]
#2217195
12/19/16 07:45 PM
12/19/16 07:45 PM
AndyF
Andy what kind of adapter you have on the oil pump? And do you make that or who does. Thanks That is a one of one custom part. It is basically an adapter for a remote filter and/or cooler but just without the internal 90 degree bends that all of the other adapters have. I was going to sell it as a product but decided it was too expensive to build in qty so I scrapped it. I use it all the time though, especially on the dyno.
[Re: AndyF]
#2223519
12/30/16 06:38 PM
12/30/16 06:38 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Well a super rigid billet dry sump pan might be an option. This one has 1/2 inch thick rails to help tie the bottom end together. I'd also probably use a cross bolt conversion if your block isn't cross bolted to start with. Who Makes that piece Andy? It's a beauty, I didn't see it on your site.
[Re: Lifsgrt]
#2223575
12/30/16 07:59 PM
12/30/16 07:59 PM
Posts: 4,210 New York
polyspheric
New York
If the purpose of the girdle is to prevent the pan rail and caps from moving, mild steel of the same thickness is far better than any aluminum.
Boffin Emeritus
[Re: Lifsgrt]
#2223795
12/31/16 01:48 AM
12/31/16 01:48 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would start with a good center weighted, lightened to the max crank. I would stay with the small BB main bearing, and consider a small rod bearing like a 2.100. You can then get a fairly light custom rod to fit your combo. The center weight crank loads the main saddles more evenly, and I saw it eliminate cap walk on my cross bolted Megablock when I switched to one. As far as the rest of the shortblock, definitely use a partial fill, and a girdle with steel main caps would be on my list. I would also sneak up on the tuneup, starting conservatively, and never look for that last hp.
