Re: New R blocks
[Re: scottb]
#2213588
12/13/16 11:00 PM
12/13/16 11:00 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
He has located the molds and everything and is trying to get Fiat to sign off on it. Did some work on it at pri last week. Hope it comes true, don't feel like starting over with a big block or 3rd gen hemi when this motor is worn out.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: New R blocks
[Re: greendart408]
#2213705
12/14/16 01:51 AM
12/14/16 01:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm not holding my breath either... my next engine will be a gen3... he may be putting the time in BUT its the money that will have to go in for this project.. I sure wouldnt put a deposit down till I see blocks ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: New R blocks
[Re: Porter67]
#2213718
12/14/16 02:04 AM
12/14/16 02:04 AM
MR_P_BODY
There are other guys saying they have blocks coming with deposits on them.. they are still waiting... I dont think they will be cheaper so who knows what the price would be IF this ever happens ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: New R blocks
[Re: Biginchmopar]
#2213799
12/14/16 11:33 AM
12/14/16 11:33 AM
Posts: 458 Michigan
BPE
I sure hope it happens I need two 9.600 48* blocks I have a brand new one on a skid I would sell but, I'm not giving it away? Rod
Re: New R blocks
[Re: BPE]
#2214231
12/15/16 02:27 AM
12/15/16 02:27 AM
1967dartgt
Hilltown Pa
I sure hope it happens I need two 9.600 48* blocks I have a brand new one on a skid I would sell but, I'm not giving it away? Rod Sold 3400 in about 4 hrs.
Re: New R blocks
[Re: Porter67]
#2214248
12/15/16 03:14 AM
12/15/16 03:14 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
In some ways to me it almost seems that the gen 3 is the future and not far off our LA based junk will simply be outdated by performance standards. That may be true.....BUT, even as popular as LS based motors are, guys are still building high performance traditional SBCs every day. Not to mention the GEN III aftermarket is small as well. No way Mopars of any kind are going to be as popular as Chevy and Ford but LA based parts will sell
Re: New R blocks
[Re: Monte_Smith]
#2214276
12/15/16 06:05 AM
12/15/16 06:05 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
That may be true.....BUT, even as popular as LS based motors are, guys are still building high performance traditional SBCs every day. Not to mention the GEN III aftermarket is small as well. No way Mopars of any kind are going to be as popular as Chevy and Ford but LA based parts will sell I've been saying this for years...whoever does sb mopar blocks, if they do them right, will make $$$$$$$$!
Brian Hafliger
Re: New R blocks
[Re: Brian Hafliger]
#2214282
12/15/16 07:58 AM
12/15/16 07:58 AM
Posts: 305 CA
David Lee
CA
i agree, if an aftermarket makes sb Mopars where we cab build them without any connection to fiat, life will be grand
Ah...so many pedestrians, so little time...
Re: New R blocks
[Re: redruM]
#2214983
12/16/16 10:38 AM
12/16/16 10:38 AM
Posts: 339 western PA
stevet340
western PA
The ROI, Return On Investment just isn't there for Mopar parts in general. We Have new blocks available, I've heard that Indy has pallets of them and Ritter took a huge leap and had them made but nobody wants to spend the money on them. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I've seen a few Rittter blocks and they are very usable! I can't see any reason for anyone else to make them, and why would you? For 1/2 dozen or so guys who will complain about the price, work involved, wrong cam bearing, deck height, lifter angle, etc,etc,etc. This isn't 1978 when you can buy a new block for $200-300, with NO OPTIONS I might add, that needs work. I can't imagine why ANYONE would want a 59* block or a 9.5 deck height or regular cam bearings for that matter. This is 2016, soon to be 2017, not 1978. As for the Ritter blocks, Ken did his best to try to make a block that EVERYONE would be able to use for whatever application they had. Guys didn't/don't buy them because they take work??? ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) There are a few guys on here that get it, as with most anything in life, you have to work for what you want, including making an engine run and making a block usuable. The rest think that because they have $$$ or spend X amount of $$$ that they shouldn't have to put the work in or have work done to a block to make it usable for THEIR APPLICATION. There is NO block out there that is ready to run direct from the manufacturer at ANY PRICE! From cylinder bore/finish, to deck height, they all need work! Not sure why everone is so bent on getting off the self parts for a race block??? ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) Good pistons all cost the same as do good rods and billet camshafts and cranks, why not use this to your advantage???? A lot on here have no problem using the latest greatest CNC ported heads from this place or that guru or whatever, not realizing they are getting a copy of one port that was originally hand ported, made for one distinct combination, not for their combination or application! ... I have a new, unmachined, short deck 60mm cam bearing, unmachined lifter bank R3 block I paid $480.00, yes, $480.00 for that I'm dying to use but haven't finished tweaking my current combination. I'm sure I will have several thousand dollars into it, but it will be perfect for my combination and that is all that matters to me. If I needed a block, Ritter would be getting a call from me and my money. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
