Re: How fast have you gone with a standard port bb head?
[Re: viperblue72]
#2214747
12/15/16 10:57 PM
12/15/16 10:57 PM
fast68plymouth
So. Burlington, Vt.
Customers car: 14:1 493, mild roller, tg4500 intake, 1050 carb, 335cfm std port SR's in a 2300lb S/G "street roadster". As I recall it went like 8.80's in decent air......it was just under 700hp. It was a very low maintenance bracket build.
[Re: viperblue72]
#2214776
12/15/16 11:19 PM
12/15/16 11:19 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
My old pump gas 518 C.I. low deck pump gas stroker (10.29 to 1 comp. ratio)ran a best of 10.30 at 127.8 MPH through the 3.0 inch exhaust system with the Magnaflow 14x3 inch ovals muffs mounted at rear bumper with me in my 1971 Duster weighing 3450 lbs. with the six pack and air cleaner on the CNC ported Eddy RPM heads. That motor on a DTS engine dyno in Ontario, CA with a .050 shorter stroke crank and 1.0 point less compression and a set of big valve mildly ported 906 heads made 612 HP @ 5500 RPM and 644 Ft. Lbs. at 4500 RPM I was really happy with that motor and the results it would produce with the changes I made on it, the last combination was a set of Indy SR M.W. heads and a Indy 400-3 intake and a holley 9375 non HP carb made 727 HP at 4300 ft in Klamath Falls OR. at 4300 ft. altitude. That was the last changes I made on that car and it made the car run 9.993 at 134.7 MPH through the full exhaust and on 91 octane OR non ethanol pump swill at Woodburn in late summer ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) You can made decent power with the standard port heads on a BB Mopar ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Better heads will make more power also with no other changes ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Now, how fast do you want to go
[Re: viperblue72]
#2214777
12/15/16 11:21 PM
12/15/16 11:21 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
440 six pack rods, Ross domed pistons, 915 heads, 2.14/1.88 Herbert roller, Team G, 1050. 575hp @ 6100 rpm. 9.97 @ 135 mph in 3,000 lb Cuda.
[image][/image]
[Re: viperblue72]
#2214778
12/15/16 11:22 PM
12/15/16 11:22 PM
fast68plymouth
So. Burlington, Vt.
I dont think 750hp would be all that hard to reach with some 350cfm heads on a high compression roller stroker build.
Then, as you say....... Just depends on what you bolt it into.
And there's also boost or spray.
'Nother one: 14:1 528, b1bs heads flowing around 325. M1 TR with 2 x 750's, .690 roller, made right about 720hp @ 6000rpm. Went 9.71 @ 140 in a 3700lb 68 charger R/T.
One more: 12:1 low deck 451, stage 6's with mild porting(300cfm), RB TG4500, .685 roller, made 650hp, went 9.31 @ 143 in a 2650lb S/G 70 Cuda.
[Re: viperblue72]
#2214824
12/16/16 12:23 AM
12/16/16 12:23 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
440 block and crank, alum rods, 11.2 to 1 Ross pistons, unported Edelbrock rpm heads, 304/640 ultradyne flat tappet cam, Isky ductile rockers, 4150 flange M-1 intake, 4150 to dominator 2" adapter with two cheater spray bars installed in it, and an 1150 Dominator on top.
simple straight-forward combo that went a best of 9.96-133 on motor alone, and 8.92-149 on spray.
2950lb 70 Challenger, glide and 9" hughes converter, 4.30 geared 8 3/4. Dependable and lots of fun!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: viperblue72]
#2214826
12/16/16 12:26 AM
12/16/16 12:26 AM
Posts: 8,349 fredericksburg,va
cudaman1969
fredericksburg,va
Dead stock 906 heads, not even a 3 angle valve job, on a 3200 pound Dart, 10.80s-122 .30 over flat tops. 37 years ago technology.
[Re: viperblue72]
#2214840
12/16/16 12:49 AM
12/16/16 12:49 AM
Thumperdart
State of confusion
Funny you ask cos my goal is to have one of or the fastest standard port window street cars at my cubes(470)and wt. now around 3050 n/a and hopefully some will share that............Last time out I went a 1.33 60 ft. and 6.15 @ 109 just lifting before the finish but went 111.78 2 years prior w/a poor 1.4? and 6.20 et so how much power is that? ![work work](/ubbthreads/images/graemlins/custom/work.gif) Been 9.79 @ 135.59 4+ years ago first pass at 3200+ lbs........ Combo; 470 stroker w/a offset ground 413 forged crank, eagle 6.385 chevy rods, JE 12.1.1 true comp. pistons, home ported 84cc(now 72)rpm's w/a 2.19 intake,Victor jr. w/adapter fully ported by Ed Mosler w/some minor adjusting since by me, an Isky solid roller w/.680-.660 and 276-281 @ .050,a home built 1050 dominator,2" Hooker Fender Wells w/3 1/2" side pipes into bullets,a Darrell Parks built 727 stock basically and rollerized,8" 5200+ Continental vert, freshly built Dr.Diff 8 3/4 nodular housing w/4/10's, 35 spline axles, and 28.10.5 w's on 10" Billet Specialties wheels............I`m curious too about wt and et's..............
[Re: cudadoug]
#2214865
12/16/16 01:41 AM
12/16/16 01:41 AM
cudaman1969
fredericksburg,va
Dead stock 906 heads, not even a 3 angle valve job, on a 3200 pound Dart, 10.80s-122 .30 over flat tops. 37 years ago technology. Cam? Converter? Gears?? Intake/carb? Mild solid cam, Crane? I'll have to ask my partner, 9 inch TCI , 5.13, TM7 800 holly with a 850 baseplate and 2 inch wooden spacer I made. Tried the Weiand, didn't help. Six-pac scoop on a glass hood. Car weighted 3021 but KK weighted 260. Headers by Ed, fender well but made better than Hooker, didn't interfere with tire. Looked like a big spider on the engine stand. Tore up every 8 inch converter we put in it, probably made better now. Won a lot of money with that car.
[Re: viperblue72]
#2214874
12/16/16 01:51 AM
12/16/16 01:51 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
There are iron headed wedge Super Stock cars that run low 9s at pretty hefty weights.....so take that for what it's worth. But that makes some alum headed strokers seem not so impressive. Too many just throw "cool guy" parts at motors instead of carefully planning the combo.
NOT saying you should use iron heads, or not build a stroker............just saying that a good combo is what makes power, not just throwing parts in a pile
[Re: viperblue72]
#2215320
12/16/16 09:42 PM
12/16/16 09:42 PM
Posts: 2,141 junction city oregon
viperblue72
Thanks for the responses. I ask because I have a lowly 383 and I am putting portted sidewinder heads and a tr on it. But my future plan is to build a bigger short block eventually. My current combo is 12.5 to 1 trw domes, mp590 cam. 2800lb valiant. I'm hoping at least 10.7s. But eventually wanna build a short block for 10.00 or better. Looks like these heads can do the trick.
