Page 5 of 6 1 2 3 4 5 6
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215640
12/17/16 02:18 PM
12/17/16 02:18 PM
Texas
mprhound Offline
mprhound  Offline
Texas
I have found another hood like this, that the whole center of the hood is raised. I want to remove the Sixpack scoop and replace it with a TA, then I will have a stock looking TA scoop that will be 3" taller because of the bulged hood. This hood gave me 3" over my ta hood.
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215645
12/17/16 02:25 PM
12/17/16 02:25 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Another pic where you can see the raised section better
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: racerx] #2215780
12/17/16 05:33 PM
12/17/16 05:33 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Originally Posted By racerx
That will work for me thumbs do you have plans for an air pan?
Yep. I've already cut out a cardboard template and will be making it out of a thin piece of wood panel, same stuff that I used with my previous one. It did such an effective job of reducing heat transfer that you could put your hand on the top of the hood and feel the temperature difference between where the hood was exposed to engine heat and where it was noticeably cooler above where the air pan sealed up against it.
was there an performance advantage with the seal hood?
A solid .1 improvement in ET and 1 MPH increase over the same old scoop and no air pan.
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: mprhound] #2215782
12/17/16 05:35 PM
12/17/16 05:35 PM
BradH Offline OP
BradH  Offline OP
That's the old (and no longer produced) MAS Six Pack Challenger hood. It's the same one "Unlawful"'s Challenger has on it.
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: GY3] #2215787
12/17/16 05:36 PM
12/17/16 05:36 PM
BradH Offline OP
BradH  Offline OP
Originally Posted By GY3
Will look better after paint...and the nekkid female Viking mural.. grin
Well, the paint's done... but I forgot to mention the nekkid female Viking mural. tonguue
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215791
12/17/16 05:39 PM
12/17/16 05:39 PM
BradH Offline OP
BradH  Offline OP
FYI, the hood is DONE and paid for. up
I took some pics, but don't have access to my 'puter to post anything at this time. down
One week, start to finish. boogie
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215793
12/17/16 05:42 PM
12/17/16 05:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I really like that 6bbl hood with the raised center section.
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: fast68plymouth] #2215854
12/17/16 08:04 PM
12/17/16 08:04 PM
BradH Offline OP
BradH  Offline OP
PICS!
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215855
12/17/16 08:05 PM
12/17/16 08:05 PM
BradH Offline OP
BradH  Offline OP
LAST 2!
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215862
12/17/16 08:23 PM
12/17/16 08:23 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks good!
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215863
12/17/16 08:23 PM
12/17/16 08:23 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Looks nice, up is that matte black or gloss?
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215870
12/17/16 08:36 PM
12/17/16 08:36 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Doesn't look near as big painted. I like it. up
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: racerx] #2215884
12/17/16 09:06 PM
12/17/16 09:06 PM
BradH Offline OP
BradH  Offline OP
I didn't care if it had the T/A-type organisol(sp?) finish anymore and asked for a semi-gloss black, instead.
It's definitely NOT a "full" gloss finish, but did end up a bit shinier that I was expecting. Based on what he showed me ahead of time as an example of the final color, I thought it was be a little more "semi" than "gloss" than it turned out. shruggy
I provided a couple of pics of Drag Pak Challengers as examples of what I was thinking the modified scoop would resemble. One of the cars in those pics was white, but also had a hood finished in a very similar way as mine turned out. I have no idea if he was thinking of that car, or if he simply sprayed what he told me he would and it turned out a little different than I thought it would. No biggie either way.
Oh, and it's definitely still BIG compared to before. But I wanted the additional clearance, and there it is.
Jeez... one week from concept to reality. I wish the rest of the car would come together this quickly.
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2215891
12/17/16 09:30 PM
12/17/16 09:30 PM
So. Burlington, Vt.
So. Burlington, Vt.
Definitely looks more "serious" now.
Should look real good on the car thumbs
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: mprhound] #2215921
12/17/16 10:49 PM
12/17/16 10:49 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
That is a old MAS hood. I know who has the molds for that hood.
69 GTX 68 Road Runner
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: JERICOGTX] #2215938
12/17/16 11:28 PM
12/17/16 11:28 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Are they still making them?
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: mprhound] #2216026
12/18/16 02:22 AM
12/18/16 02:22 AM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I know MAS isn't around any more, but not if somebody else is actually making the same hoods. That's a nice looking hood, too.
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: BradH] #2216763
12/19/16 01:19 AM
12/19/16 01:19 AM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
"Keefe - Is your car any closer to running again than mine? And Douglas better have his sh!t running when I come rumbling back into MIR, too."
BRAD - The finished hood looks great, I can't wait to see it on the challenger.
I hope to be done with the Duster around June.
Douglas is running but he's just been street cruising here lately.
Maybe this summer we all can play hooky from work and do a track rental at MIR..
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: keefe] #2216852
12/19/16 09:39 AM
12/19/16 09:39 AM
BradH Offline OP
BradH  Offline OP
Renting the track to help get all the changes to our cars figured out is a great idea. up
Re: PICS OF "DRAG PAK'D" T/A HOOD SCOOP ADDED [Re: PorkyPig] #2216856
12/19/16 10:20 AM
12/19/16 10:20 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I can find out. The molds were all remade just before MAS closed. I happened to stumble onto someone that knows the guy that bought all the molds. I asked if he could make me a Road Runner 6 pack hood, and it was done in a couple weeks. Was the nicest hood I ever saw come out of the molds.
