Re: Wire up a RTR distributor help
[Re: Crusty2r]
#2211745
12/11/16 10:04 AM
12/11/16 10:04 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
no instructions?
Looks like red to 12V ignition source and black to coil -
[Re: Supercuda]
#2211772
12/11/16 11:51 AM
12/11/16 11:51 AM
RapidRobert
the coil positive primary terminal and the module in the dist both need (1) to be recieving fire (2) and recieving fire in run and in crank. I'm assuming the ballast is bypassed (the ign1/ign2 circuits are tied together) so the seperate run/crank circuit potential (#2) ain't an issue.
[Re: RapidRobert]
#2211868
12/11/16 02:45 PM
12/11/16 02:45 PM
Posts: 16,168 Omaha Ne
TJP
Omaha Ne
the coil positive primary terminal and the module in the dist both need (1) to be recieving fire (2) and recieving fire in run and in crank. I'm assuming the ballast is bypassed (the ign1/ign2 circuits are tied together) so the seperate run/crank circuit potential (#2) ain't an issue. I would change "fire" in your response to voltage as it may be confusing. And I also would not ASSUME the ballast is bypassed . It may be the root of his problem And no offense meant Robert just trying to helpful to the OP
[Re: TJP]
#2211882
12/11/16 03:03 PM
12/11/16 03:03 PM
RapidRobert
(1) Noted (2) point taken (3) we're good brother
[Re: Crusty2r]
#2212026
12/11/16 06:54 PM
12/11/16 06:54 PM
Supercuda
About to go away
About to go away
up yours
Pretty much decided CRT Performance SUX!
No info on their website to speak of.
The black has to go to the coil negative, otherwise it will never spark. Nothing else should be on the coil negative terminal.
You will need 12V on the red wire in both start and run, a quick jumper to the battery will do that for testing purposes, but you need to splice the IGN1 and IGN2 wires together to feed the red wire. Those wires should be present at the ballast, since you don't say what the vehicle is the simplest method is to jumper out the ballast and take the red wire to the coil +. Assuming the coil from CRT can handle full 12V, the site's instructions leave something to be desired, like instructions.
[Re: Supercuda]
#2212069
12/11/16 07:52 PM
12/11/16 07:52 PM
RapidRobert
You will need 12V on the red wire in both start and run, a quick jumper to the battery will do that for testing purposes, but you need to splice the IGN1 and IGN2 wires together to feed the red wire. Those wires should be present at the ballast, since you don't say what the vehicle is the simplest method is to jumper out the ballast and take the red wire to the coil +. Assuming the coil from CRT can handle full 12V. What Supercuda said. Pull the yellow wire off of the "ign" terminal on the starter relay to disable the starter (no need to run down the batt for testing & when it does end up starting using the alt to charge up a depleted battery causes problems) & with a helper to hold the key to "start" get the wiring right so everything that needs to be fed is being fed in ign2 (cranking, the brown wire circuit) and in ign1 (run, the bue wire circuit) and also get everything straight on the neg coil primary terminal.
[Re: Crusty2r]
#2212365
12/12/16 08:16 AM
12/12/16 08:16 AM
Posts: 5,338 the house on the left.
cogen80
you eliminate the ballast resistor..
tie all the wires together that used to go to the ballast. then run a wire from that connection over to the coil. now it has power in the start and run position... make sure the black wire goes to a good ground.
[Re: TJP]
#2212729
12/12/16 07:32 PM
12/12/16 07:32 PM
RapidRobert
be aware that jumpering the start and run wires together, if not done correctly, can / will backfeed to the starter relay which can then cause it to have the Start signal in the run position which could result in constant starter engagement. Yeah in the archives in the "elec topics" then clicking on the diagram in "awesome ECU wiring diagram" it shows the yellow wire which triggers the starter relay to crank is T'd over to the downstream side of the ballast. I always thought that was a misprint but someone says it is correct in a few apps (I ain't seen it). Yes you would want to eliminate that "T" if it is present & you are connecting the blue/brown wire circuits. EDIT with the key "on" if there is no voltage at the yellow "ign" wire/terminal on the starter relay you're good
