Re: any issues putting a 360 magnum in to a 74 e body? [Re: Andrewh] #2208500
12/06/16 01:24 AM
12/06/16 01:24 AM
Alright, thank you
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2211416
12/10/16 07:52 PM
12/10/16 07:52 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
still cant find that m1 intake
5549 post on old board
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2211503
12/10/16 09:42 PM
12/10/16 09:42 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I have a M1 that I'd sell if I get an Edelbrock for mine.
Also to correct myself, 340 E/manifolds do fit on the Magnum heads as well as the 340 valve covers.
I'm also looking for some of the black cast MP 10 bolt Magnum valve covers.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2211924
12/11/16 05:11 PM
12/11/16 05:11 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
Cana pro former intake manifold be drilled to fit magnum heads??n
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2211944
12/11/16 05:30 PM
12/11/16 05:30 PM
moparmarks Offline
moparmarks  Offline
Don't see how.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: any issues putting a 360 magnum in to a 74 e body? [Re: moparmarks] #2212081
12/11/16 09:16 PM
12/11/16 09:16 PM
Never tried it but I read once where a guy drilled down vertical into the LA intake then used spacers under the bolt head with an angle on the lower side of the spacer to match the angle on the LA intake. If I did not have a Mag intake I would try it
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2212133
12/11/16 09:59 PM
12/11/16 09:59 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Ted, Edelbrock makes a Performer RPM Airgap for Magnum motors. Summit sells a Chinese knockoff called a Crosswind. A long time ago, a Moparts member had a jig to redrill Magnum heads to fit an LA intake. If I remember right, it disappeared and has never been seen again. Check on Rock Auto for a 5.9 flex plate. The harmonic balancer and the flex plate have to match on Magnum motors. As for Magnum exhaust manifolds, there are different versions. The most common have 1 7/8 exits, and the better ones have larger openings. 2 1/4, I think?
Re: any issues putting a 360 magnum in to a 74 e body? [Re: JDMopar] #2212146
12/11/16 10:11 PM
12/11/16 10:11 PM
I was one of the ones who rented the "jig" when it was in circulation. I think a person could mockup the LA intake on the longblock then make a centerpunch mark down the LA intake manifold holes onto the head deck surface then remove the intake/heads & drill/tap the heads in that location(s) which was what the jig did. If the area on the heads you would be drilling into was solid it would work fine (with the jig it was borderline)
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2212167
12/11/16 10:33 PM
12/11/16 10:33 PM
moparmarks Offline
moparmarks  Offline
http://www.edelbrock.com/automotive/mc/manifolds/chrysler/rpm-air-gap-sb.shtml
One difference between the Magnum and LA is the coolant bypass hose. Different size nipple and different angle.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: any issues putting a 360 magnum in to a 74 e body? [Re: 05dakota] #2212171
12/11/16 10:40 PM
12/11/16 10:40 PM
moparmarks Offline
moparmarks  Offline
Looks like they made 2 Air Gaps for the Magnum. I need the one that has the tower boss right behind the thermostat.
https://www.summitracing.com/parts/edl-7577
Desert Mopar Metal
Grand Jct. CO
970-261-7039
