Carter M6270 Fuel Pump? #2210026
12/08/16 12:29 PM
12/08/16 12:29 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Does a Carter M6270 fuel pump require the use of a pressure regulator? According to them, it doesn't, but I was hoping to hear from folks who actually use one.
https://www.summitracing.com/parts/crt-m6270
Re: Carter M6270 Fuel Pump? [Re: mopowers] #2210134
12/08/16 03:42 PM
12/08/16 03:42 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
with a rated output of 6.9 to 8.1 it would depend on the carb(S) that you're using.
Edelbrocks and some factory carbs do not like more than 6 PSI, Holleys typically want 7 or so but may tolerate the 8.1
beer
Re: Carter M6270 Fuel Pump? [Re: mopowers] #2210167
12/08/16 04:51 PM
12/08/16 04:51 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Sorry. The carb would be a Holley 750DP
Re: Carter M6270 Fuel Pump? [Re: mopowers] #2210315
12/08/16 08:39 PM
12/08/16 08:39 PM
No actual exp with that pump but the ones I've checked (even mech ones) all seem to put out more PSI than what they are rated which is OK if you reg it down as needed
