Re: Epoxy primer Help
[Re: Beep Beep]
#2208706
12/06/16 02:09 PM
12/06/16 02:09 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I wouldn't use the new lead free ppg epoxy. It's non sanding and it pretty much sucks because of that... same with omni, nason etc. Maybe as a sealer, but not on bare metal.
If you want good epoxy you can sand, use SPI.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2208822
12/06/16 05:28 PM
12/06/16 05:28 PM
Posts: 2,938 California
1970mopar
California
It's non sanding and it pretty much sucks because of that. That's because its designed as a NON SANDING EPOXY PRIMER. Its only purpose is to protect the base metal from corrosion and give a solid base for top coat materials. It was never designed to be sprayed down heavy, or to fill.
[Re: Beep Beep]
#2208828
12/06/16 05:42 PM
12/06/16 05:42 PM
Posts: 765 Vancouver, WA
Cuda Cody
Vancouver, WA
If you're looking for a sand-able primer, there's fantastic primers on the market for sanding. But they don't work as well as top end Epoxy primers when it comes to protecting from rust. V Prime DPS3051 is one of the best sanding primers for holdout and gloss retention that I've found. You'll crap yourself when you see the price per gallon, but don't clean that crap off yourself as you'll just be crapping yourself again when you see how fast and easy it sands.
1970 Challenger T/A 4-Speed 1970 Challenger T/A 4-Speed 1970 Challenger T/A Auto 1970 Challenger R/T Auto 1970 Challenger Auto 1970 Challenger RT 440+6 4-Speed 1970 Challenger RT 440+6 4-Speed 1970 Hemi Challenger 4-Speed 1970 Hemi Cuda 4-Speed 1971 Cuda Auto 1971 Cuda 4-Speed LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
[Re: Beep Beep]
#2208848
12/06/16 06:11 PM
12/06/16 06:11 PM
Cuda Cody
Vancouver, WA
This is not a comment specifically about any brand, but I've found really talented painters can pretty much make any product look good. But for people like me who some would call average, using really high end quality materials makes it much easier to get a beautiful result.
[Re: 1970mopar]
#2209126
12/07/16 02:06 AM
12/07/16 02:06 AM
Silver70
Rust Belt, SW PA
It's non sanding and it pretty much sucks because of that. That's because its designed as a NON SANDING EPOXY PRIMER. Its only purpose is to protect the base metal from corrosion and give a solid base for top coat materials. It was never designed to be sprayed down heavy, or to fill. I'm sure they call it non sanding because of how crappy it is! I do epoxy then put the fillers on and then high build primers... so what do I do with non sanding when I try and do body work over it? I know I end up with clogged sandpaper. You can buy and use all you want, but I won't use it if it's free!
[Re: Beep Beep]
#2209334
12/07/16 02:27 PM
12/07/16 02:27 PM
Silver70
Rust Belt, SW PA
The only negative of spi for me is cold weather... you must keep it above a certain temp for 24hrs. Otherwise it's all I'll use once I'm out of the leaded ppg I stockpiled As far as doing 2k primer or putty directly over the non sanding ppg, you still end up sanding into it and ruining a lot of sand paper. You can get epoxy for half the price that will do the same thing.
