reusing cometic head gaskets #220886
02/11/09 12:21 AM
02/11/09 12:21 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
i am pulling the heads due to a water leak, i used cometics with copercoat on both sides, whats the best way to clean and reuse, and who has reused with sucess, thanks mike
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: reusing cometic head gaskets [Re: Stroker Scamp] #220887
02/11/09 12:27 AM
02/11/09 12:27 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
soak a rag with brakeclean and keep wipeing it down till the copper coating comes off
use two to three rags if coating builds up on the rags
this is my second time using the cometic gaskets
1.39 9.85 - 137 mph
Re: reusing cometic head gaskets [Re: Stroker Scamp] #220888
02/11/09 12:27 AM
02/11/09 12:27 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Three times reused with success, cleaned with laquer thinner and let dry b4 recoating with your copper coat. I will not reuse a 4th time. I heard 3 times max.
Re: reusing cometic head gaskets [Re: wheelsup68dart] #220889
02/11/09 12:41 AM
02/11/09 12:41 AM
pacific northwest
pacific northwest
did you keep them together (not cutting the rivets), mike
Re: reusing cometic head gaskets [Re: Stroker Scamp] #220890
02/11/09 01:33 AM
02/11/09 01:33 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I kept mine together without a problem.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: reusing cometic head gaskets [Re: Irun5snd8th] #220891
02/11/09 02:12 AM
02/11/09 02:12 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I kept mine together also.
I also used brake clean on mine. I was advised afterward by another board member that the brake clean would dmamge the rubber coating on the gaskets. That was 2 years ago, and they're still fine.
FWIW I put them in dry when they were new, and just a light spray of copper coat the second time round.
Re: reusing cometic head gaskets [Re: Stroker Scamp] #220892
02/11/09 08:01 AM
02/11/09 08:01 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Not sure how it is going to work, but I just re-used mine the weekend at BG's place. We cut one rivet so the other would keep all 3 pieces together. Then after cleaning real good I swung the outer layers away and coated the steel shim with copper on each side, swung the outers back into place after the steel shim dried some and put one coat on the outer layers deck side and head side.
