Re: Hydraulic Lifters & Spring Pressure [Re: YO7_A66] #2205273
11/30/16 03:27 PM
11/30/16 03:27 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
in that cam swap article Andy did, the comp hydraulic went to 7000rpm.
http://www.moparts.org/Tech/Archive/bb/Lobe.html
seems like you could get quite a bit more rpm than 5600 with stiffer springs and stiff pushrods, even if you are running a more aggressive rocker ratio.
Re: Hydraulic Lifters & Spring Pressure [Re: YO7_A66] #2205287
11/30/16 03:59 PM
11/30/16 03:59 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I've sold quite a few cams with the same lobes as what Andy ran in that test and I can tell you that his results on how high those profiles will go isn't typical.
They are usually "done" by around 6k, and lower as the ratios are increased.
If you go back and check out Dulcichs article on the 446 from October 2005 you'll see how the usual scenario plays out.
Re: Hydraulic Lifters & Spring Pressure [Re: fast68plymouth] #2208702
12/06/16 02:02 PM
12/06/16 02:02 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
The Shubeck/Smith Machine is the best hydraulic lifter for radical lobes/rpm. They have a ceramic puck and can be used on many cams without break in. They are around 1,000 bucks a set but buy only once. I run 200 seat and 425+ over the nose at 7000+. Be vigilant on checking springs as if they get weak you can bounce the lifter and the ceramic has been known to shatter making a real mess. I have been using these for a long time without issue but am fanatical about checking things over.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Hydraulic Lifters & Spring Pressure [Re: fast68plymouth] #2208756
12/06/16 03:14 PM
12/06/16 03:14 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Do you have a link to Dulcichs article?
Re: Hydraulic Lifters & Spring Pressure [Re: YO7_A66] #2208776
12/06/16 03:37 PM
12/06/16 03:37 PM
So. Burlington, Vt.
So. Burlington, Vt.
You'll have to try a search and see if you can find it.
I have the actual magazine.
Mopar Muscle oct 2005
Try this:
http://www.hotrod.com/articles/mopp-0510-440-engine-dyno-test/
Re: Hydraulic Lifters & Spring Pressure [Re: fast68plymouth] #2209852
12/08/16 02:57 AM
12/08/16 02:57 AM
USA
B5496RR Offline
B5496RR  Offline
USA
WOW! Both very good articles.
Also a great post here with a lot of good info!
The question for me is what HYDRAULIC lifter was being used in the two different tests?
Re: Hydraulic Lifters & Spring Pressure [Re: YO7_A66] #2210024
12/08/16 01:27 PM
12/08/16 01:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
There is some interesting info in the 446 build article dyno numbers of the later tests that they don't talk about, but the results bear it out.
Re: Hydraulic Lifters & Spring Pressure [Re: fast68plymouth] #2269414
03/14/17 04:44 PM
03/14/17 04:44 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
bumping this, i'm curious if the y07 got any more rpm out of his combo...
Re: Hydraulic Lifters & Spring Pressure [Re: krautrock] #2269415
03/14/17 04:49 PM
03/14/17 04:49 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am still interested too! Our weather has not been good so the car still sets.
Thanks for the bump and I will check back in once I can get the new spring pressures tested.
