What requires a rotating assembly to be rebalanced? #2206251
12/02/16 01:22 AM
12/02/16 01:22 AM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
If a rotating assembly was previously balanced and one or a combo of the following was performed does the rotating assembly need to be re-balanced?
Recondition connecting rods
Replace pistons rings
Replace rod bearings
Polish crankshaft
Is there a general guideline of when a rebalance should take place?
Re: What requires a rotating assembly to be rebalanced? [Re: B5496RR] #2206262
12/02/16 01:40 AM
12/02/16 01:40 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
A before and after of the rods would've told you but I doubt their weights changed enough to make a difference. Were they resized?
Mopar to the bone!!!
Re: What requires a rotating assembly to be rebalanced? [Re: B5496RR] #2206263
12/02/16 01:43 AM
12/02/16 01:43 AM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
No repairs have been performed...
It's a general question
Re: What requires a rotating assembly to be rebalanced? [Re: B5496RR] #2206265
12/02/16 01:44 AM
12/02/16 01:44 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
No reason to re-balance unless some weight is removed or added.
Re: What requires a rotating assembly to be rebalanced? [Re: B5496RR] #2206266
12/02/16 01:47 AM
12/02/16 01:47 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Changes have to be pretty substantial in most cases to need a rebalance. Anything you mentioned is miniscule
Re: What requires a rotating assembly to be rebalanced? [Re: 72Swinger] #2206269
12/02/16 01:49 AM
12/02/16 01:49 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Recondition connecting rods----- No but a quick check never hurts.
Replace pistons rings-----No
Replace rod bearings-----No
Polish crankshaft-----No
I have a gram scale that I balance my pistons and rods before I even take them to the shop. That way we can double-check each other. I always ask for a copy of the balance sheet for every assembly I have done. They also keep a copy too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What requires a rotating assembly to be rebalanced? [Re: B5496RR] #2206344
12/02/16 05:02 AM
12/02/16 05:02 AM
As far as recondition connecting rods, if you have them resized and or replace the bolts your probably good, if your replacing the original rods with a different set of recondition rods I would definitely have them check for balance on both ends and length twocents I went through around twelve sets of LY rods years ago when I was still racing NHRA stock, the factory standards for production motors is not real precise shock shruggy
I've saw .017 in length and a hoop of weight differences (35 grams from the lightest to the heavy one) in those rods shruggy
Re: What requires a rotating assembly to be rebalanced? [Re: B5496RR] #2206356
12/02/16 08:10 AM
12/02/16 08:10 AM
crabman173
crabman173
Most shops know that about a little under 30 grams anywhere and you better redo it--under that --it is usually ok---many factory tolerances would accept that back in the day--I agree with the others NO need to re-balance even if you grind crank--go to different rod bearings etc--No worry!
Re: What requires a rotating assembly to be rebalanced? [Re: ] #2206373
12/02/16 10:32 AM
12/02/16 10:32 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
Don't laugh when I ask this. But you definitely need to rebalance when you replace pistons correct?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: What requires a rotating assembly to be rebalanced? [Re: dart440_72] #2206384
12/02/16 11:22 AM
12/02/16 11:22 AM
moparx Offline
moparx  Offline
i would guess only if they are heavier, or lighter than the original, balanced, set. unless the total set is only 10 grams or so[? amount] different in weight. of course, you would weigh each piston and get each to weigh the same as you would normally. is this a correct assumption ? if not, please correct me with the weight difference for the re balance necessity.
beer
