Re: tunnel ram with single top
[Re: Chris Vanover]
#2204795
11/29/16 10:52 PM
11/29/16 10:52 PM
crabman173
crabman173
Tunnel rams with single fours are a terrible idea--they run the end cylinders so lean it is scary--we tried one for grins on our Mopar engine masters deal--they said any cast single 4 so after we did good with our normal set up we tried a tunnel ram single four for one pull--the two front and two rear header pipes went cherry red on the dyno --you can see it in the video They were crazy lean compared to the others-- They are great swap meet items but no way I would run one
[Re: Chris Vanover]
#2204934
11/30/16 01:26 AM
11/30/16 01:26 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Has to be set up right but can work very well. Very common in Comp Eliminator
The "MAN" on that setup is John Marcella
[Re: Chris Vanover]
#2204982
11/30/16 02:16 AM
11/30/16 02:16 AM
hustlin hoosier
Charlie Westcott Built ours, all billet.
[Re: Chris Vanover]
#2205747
12/01/16 09:02 AM
12/01/16 09:02 AM
crabman173
crabman173
I was just saying the as cast stocker units were a bit sketchy for sure pro set ups work well
[Re: Chris Vanover]
#2205930
12/01/16 04:38 PM
12/01/16 04:38 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Some take the teepee to new heights for sure Marcella built Uratchko designed Most of these intakes in the class we run just look pregnant, not just the top but the entire intake. How much "cast" they are is always good for some speculation. Some really cool pieces in the NA10.5 ranks for sure. The manifold from the Vette is at Slawko now getting massaged again for the third time in three seasons. Be nice if they did away with the weight penalty for a sheet metal deal as it would be WAY cheaper
[Re: Chris Vanover]
#2206655
12/02/16 09:26 PM
12/02/16 09:26 PM
Posts: 5,620 long island NY
Ari440
long island NY
Would this be considered the best singal four barrel setup
1.39 9.85 - 137 mph
