Re: 8-3/4 and Dana 60?
[Re: Scamp408]
#2204434
11/29/16 02:21 PM
11/29/16 02:21 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
I think it might change small bolt pattern vs big bolt. I have dual pattern axles from moser for small and big bolt. My car was originally a small bolt and the offset is 2.36". I just measured this for my Dana 60 build.
68 Barracuda Formula S 340
[Re: Scamp408]
#2204462
11/29/16 02:54 PM
11/29/16 02:54 PM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
Yes that's it. Is that the std or a body number I was thinking that 2.36" was for the standard 8 3/4 and Dana. Call Drdiff, he can answer any questions you have.
[Re: Scamp408]
#2204483
11/29/16 03:37 PM
11/29/16 03:37 PM
Posts: 2,709 NJ central
Scamp408
NJ central
Strange engineering list it as 2.66
[Re: Scamp408]
#2204496
11/29/16 04:01 PM
11/29/16 04:01 PM
Posts: 43,748 Bend,OR USA
Cab_Burge
Are you wanting the differences in the axle lengths between a Dana 60 on the passenger side and driver sides( 8 3/4 axles are the same length on both sides) or are you wanting the distance between the axle flanges and the rear end axle bearing mounting flanges?
[Re: Scamp408]
#2204723
11/29/16 09:08 PM
11/29/16 09:08 PM
Posts: 26,545 Rio Linda, CA
John_Kunkel
Rio Linda, CA
On factory BBP axles, the "A" dimension is 2.525"
