Re: Hydraulic Lifters & Spring Pressure
[Re: YO7_A66]
#2205287
11/30/16 03:59 PM
11/30/16 03:59 PM
fast68plymouth
So. Burlington, Vt.
I've sold quite a few cams with the same lobes as what Andy ran in that test and I can tell you that his results on how high those profiles will go isn't typical. They are usually "done" by around 6k, and lower as the ratios are increased.
If you go back and check out Dulcichs article on the 446 from October 2005 you'll see how the usual scenario plays out.
[Re: fast68plymouth]
#2208702
12/06/16 02:02 PM
12/06/16 02:02 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
The Shubeck/Smith Machine is the best hydraulic lifter for radical lobes/rpm. They have a ceramic puck and can be used on many cams without break in. They are around 1,000 bucks a set but buy only once. I run 200 seat and 425+ over the nose at 7000+. Be vigilant on checking springs as if they get weak you can bounce the lifter and the ceramic has been known to shatter making a real mess. I have been using these for a long time without issue but am fanatical about checking things over.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
#2208756
12/06/16 03:14 PM
12/06/16 03:14 PM
Posts: 8,368 fredericksburg,va
cudaman1969
fredericksburg,va
If you go back and check out Dulcichs article on the 446 from October 2005 you'll see how the usual scenario plays out. Do you have a link to Dulcichs article?
[Re: YO7_A66]
#2210024
12/08/16 01:27 PM
12/08/16 01:27 PM
fast68plymouth
So. Burlington, Vt.
There is some interesting info in the 446 build article dyno numbers of the later tests that they don't talk about, but the results bear it out.
[Re: krautrock]
#2269415
03/14/17 04:49 PM
03/14/17 04:49 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am still interested too! Our weather has not been good so the car still sets. Thanks for the bump and I will check back in once I can get the new spring pressures tested.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
