Re: 2 basic? timing spec/oil capacity 225
[Re: timeklr]
#2203678
11/28/16 01:07 AM
11/28/16 01:07 AM
Posts: 10,670 Freeport IL USA
poorboy
Freeport IL USA
I always viewed what the book (or the emission label) gave you for timing as a starting point for timing. Every motor I ever ran across was slightly different then the book or l;able stated when the motor ran its best.
If you have several dipsticks to choose from, change your oil & filter, leaving it down 1 quart, and run the motor to fill the filter. Now, choose a dipstick that shows the oil level at add 1 quart. Then add the quart, and check the dipstick says the oil level is correct.
If you do not have a dip stick that matches the 1 quart low, I would choose the longest dip stick you have, cut the bottom off, and remark it with a punch at the add 1 quart level, and another punch mark after the quart has been added. Gene
[Re: timeklr]
#2204272
11/29/16 04:41 AM
11/29/16 04:41 AM
Posts: 3,911 Oregon
hooziewhatsit
IMO, forget what the book says about timing. The quick way to do it is to set the total timing at ~3000 RPMs (I'm not sure what that should be for a slant 6), and let the initial fall wherever it does.
Lots of stuff here on setting your timing curve and initial/total/vacuum advance tuning.
[Re: poorboy]
#2204562
11/29/16 05:12 PM
11/29/16 05:12 PM
Posts: 73 Sunny South
Noah Zarq
Sunny South
If you do not have a dip stick that matches the 1 quart low, I would choose the longest dip stick you have, cut the bottom off, and remark it with a punch at the add 1 quart level, and another punch mark after the quart has been added. Gene This is exactly what I did for my 225, as it had a broken dipstick that was about 8 miles long. I used a generic chrome aftermarket Chevrolet dipstick I picked up at Auto Stoned for just a couple bucks, then filed my own notches for full, add, etc. Been that way 8 years now.
[Re: timeklr]
#2204843
11/30/16 12:04 AM
11/30/16 12:04 AM
poorboy
Freeport IL USA
gene thank you for the reply my issue is the truck has no sticker and the book says to look at it for timing ....the other is I do not know what the capacity is of the trucks oil pan is if anyone can help me I d it I can then fill it a quart short and find the stick hat matches just not sure how much is a quart low 4. or 5. quarts to start with??? not sure i'm describing issue right thanks again for the response If you are unsure of how much oil the pan holds, I would assume it would hold 4 quarts + one for the oil in the filter, for a total of 5 quarts. Put 4 in with a new filter, run the motor, and mark the dipstick as the add 1 quart level. Then add a quart and mark the dipstick as the full level. As for the timing, set it so the motor starts. Disconnect the vacuum advance & plug the hose. Run the motor up to 2500 rpm. Set the total advance at 30 degrees before tdc (according to the old Mopar Performance engine book). Let the engine idle, check the timing. Then reattach the vacuum advance hose and note how much it advances the timing, as you may adjust the timing if you have a ping with the vacuum hose attached. Gene
[Re: poorboy]
#2204958
11/30/16 01:54 AM
11/30/16 01:54 AM
Posts: 122 tn
timeklr
tn
gene thank you for the reply my issue is the truck has no sticker and the book says to look at it for timing ....the other is I do not know what the capacity is of the trucks oil pan is if anyone can help me I d it I can then fill it a quart short and find the stick hat matches just not sure how much is a quart low 4. or 5. quarts to start with??? not sure i'm describing issue right thanks again for the response If you are unsure of how much oil the pan holds, I would assume it would hold 4 quarts + one for the oil in the filter, for a total of 5 quarts. Put 4 in with a new filter, run the motor, and mark the dipstick as the add 1 quart level. Then add a quart and mark the dipstick as the full level. As for the timing, set it so the motor starts. Disconnect the vacuum advance & plug the hose. Run the motor up to 2500 rpm. Set the total advance at 30 degrees before tdc (according to the old Mopar Performance engine book). Let the engine idle, check the timing. Then reattach the vacuum advance hose and note how much it advances the timing, as you may adjust the timing if you have a ping with the vacuum hose attached. Gene Thank you Gene will do, as always the knowledge and opinion of this board is appreciated thanks again.
[Re: timeklr]
#2205454
11/30/16 08:38 PM
11/30/16 08:38 PM
RapidRobert
I'd set the initial at 15 on ported. iirc the good std ballpark total for a /6 is 32 (initial+slots/can capped). the $22 FBO plate is by far the easiest/cheapest way to set/alter/change the slot lengths (total).
