slap stick shiftier #2203159
11/27/16 02:59 AM
11/27/16 02:59 AM
IL.
4406RR Offline OP
4406RR  Offline OP
IL.
Dose any one still make the conversion for the 69 and earlier shiftiers?
http://img.photobucket.com/albums/v390/jerggy13/c7374b0e.jpg
midamericacustoms.com lowering kit for the 72-93 dodge ram and ram charger 4406rr@gmail.com
Re: slap stick shiftier [Re: 4406RR] #2203167
11/27/16 03:08 AM
11/27/16 03:08 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
There have been things out there, BUT I don't think they work all that well, BUT you can use a '70-up slapstick shifter in an earlier car if you shorten the effective length of the upper arm on the through-floor shaft from 2.5" to 2.25" (just drill a new hole). All other brackets/rods are for the early car.
There is also a long handle version that was optional in late 70s B-bodies. I have one as well as a '70 shifter. One of them will be in my '67 Barracuda convertible when I get it on the road.
This is the '70 shifter with an early knob mounted in my Barracuda.
Re: slap stick shiftier [Re: 4406RR] #2203428
11/27/16 06:30 PM
11/27/16 06:30 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Cool info Jim up
Re: slap stick shiftier [Re: 4406RR] #2203454
11/27/16 07:25 PM
11/27/16 07:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I welded & cut slots in my stock one, also converted it to cable, works great. it is not pretty, 1st to 2nd just bump shifter & it locks in 2nd,,push button & move to 3rd,it wont go any further until you let go of the button.
Re: slap stick shiftier [Re: 4406RR] #2203871
11/28/16 02:38 PM
11/28/16 02:38 PM
IL.
4406RR Offline OP
4406RR  Offline OP
IL.
nice
Re: slap stick shiftier [Re: 4406RR] #2204138
11/29/16 12:22 AM
11/29/16 12:22 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I saw this on another forum and figured that it might be an idea that would work. I still like the slap stick better, but this another idea.
Re: slap stick shiftier [Re: 4406RR] #2205057
11/30/16 04:48 AM
11/30/16 04:48 AM
IL.
4406RR Offline OP
4406RR  Offline OP
IL.
dose any one have a e-body shiftier for sale
