Page 9 of 16 1 2 7 8 9 10 11 15 16
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2190977
11/06/16 10:09 PM
11/06/16 10:09 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Trying to pic up speed before it becomes too cold to work on her.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2199615
11/20/16 10:35 PM
11/20/16 10:35 PM
sgcuda Offline OP
sgcuda  Offline OP
Well, I didn't care for that hoop, and by the responses, I'm guessing neither did anybody else. Added main hoop diagonals, a lower cross brace between the diagonals, and a longer hoop mounted more forward than the last one.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2199646
11/20/16 11:30 PM
11/20/16 11:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks great but now it's too heavy w/all of those extra bars.........lol
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2199676
11/21/16 12:17 AM
11/21/16 12:17 AM
sgcuda Offline OP
sgcuda  Offline OP
It's ok. All of the added weight is close to the rear axle.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2199687
11/21/16 12:40 AM
11/21/16 12:40 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
TRUE..........
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2199710
11/21/16 01:07 AM
11/21/16 01:07 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks like you've made good progress! up
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2202910
11/26/16 05:24 PM
11/26/16 05:24 PM
sgcuda Offline OP
sgcuda  Offline OP
Thanksgiving and part of Saturday progress. Taking a break. Have to go look at a computer.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2202912
11/26/16 05:30 PM
11/26/16 05:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice................ beer
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2202995
11/26/16 09:05 PM
11/26/16 09:05 PM
sgcuda Offline OP
sgcuda  Offline OP
Starting to look pretty good, if I do say so, myself.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2203463
11/27/16 07:43 PM
11/27/16 07:43 PM
sgcuda Offline OP
sgcuda  Offline OP
OK. Out of gas. This is where I landed after this weekend. Now, to get some Argon, and get some sleep.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2203515
11/27/16 09:20 PM
11/27/16 09:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You've come a LONG way rookie.............. biggrin
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2203525
11/27/16 09:43 PM
11/27/16 09:43 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Looks good.........Me personally I would have run the lower bar all the way across hoop instead of between kickers. And the reason is, because I "think" to be legal with a FC cage, your lower supports must attach to main rail or a floor bar. As constructed you really don't have a spot for lower supports.
And to be clear, by "supports" I am referring to the two bars directly behind driver. Pretty sure they have to extend from top of main hoop to floor. Not sure what you have will pass
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2203531
11/27/16 09:54 PM
11/27/16 09:54 PM
sgcuda Offline OP
sgcuda  Offline OP
Monte: The lower cross bar and angled supports are copied directly out of the SFI book (pg.13 25.4B manual). The only difference is that they have 2 lower uprights from the lower crossbar to the rear frame crossmember, but that is for a four link setup. My ladder bar crossmember is way too far forward for that. That is why I added 2 more diagonals going inboard, to support the funny car hoop. Also, I have an additional upper crossmember in the hoop. That was mostly by mistake, working off of how the bar gets put in when just building an 8 point roll bar. Decided to leave it for extra strength.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2203538
11/27/16 10:07 PM
11/27/16 10:07 PM
sgcuda Offline OP
sgcuda  Offline OP
First, I guess I need to find out who makes the final call, SFI or NHRA. Then, maybe I can send them some pics and get some feedback. Thanks for the heads up, Monte. It will be a lot easier to make modifcations now then after car is done and painted.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2203541
11/27/16 10:11 PM
11/27/16 10:11 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
They don't care that it is a ladder bar car or a 4 link car. That was my point, the two lower supports must tie in at the bottom........yours don't.
If your lower bar was all the way across, your two lower FC supports could land on bar from main hoop to rail and one on the rail
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2203548
11/27/16 10:18 PM
11/27/16 10:18 PM
sgcuda Offline OP
sgcuda  Offline OP
I get it. It's a pretty straight shot from the fc hoop to the ladder bar x member. I could come straight down from the bottom turn with a straight leg, and tie it into a rear driveshaft hoop.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2207196
12/03/16 09:52 PM
12/03/16 09:52 PM
sgcuda Offline OP
sgcuda  Offline OP
For anyone that is interested, I finished installing LED lighting in my garage. WHAT A DIFFERENCE!!! Borrowed a camera from work. Here's some better pics of my project so far.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2207431
12/04/16 08:52 AM
12/04/16 08:52 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I think the reason you had trouble with the funny car cage is your cross bar on the main hoop is about 6" give or take a few to high. that's why you had to add all the extra bars. make sure your helmet wont go between the bars on the drivers right side, the distance between the bars looks large on the pics.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2207432
12/04/16 09:11 AM
12/04/16 09:11 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
It does look bright which lights did you get?
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2207519
12/04/16 12:59 PM
12/04/16 12:59 PM
sgcuda Offline OP
sgcuda  Offline OP
Quicktree: My helmet won't fit between any two bars. The lower bar on the inside of the funny car cage is close to elbow level, too low to get the helmet through unless my head pops off my shoulders first. I need to get a shot with the seat installed and someone sitting in it with the helmet on.
Racerx: I went from 2 bulb 48" fluorescent to UT workshop LED lights from Lowes. $49 each. Used four of them in a 22 x 25 shop. Instant on when the light switch is hit. I have a center outlet where the electric door opener is mounted. Might put a fifth light there to kill any other shadows while welding. There is a pull string on the light to turn them on and off, which will be needed for the center outlet, which is always live.
[image][/image]
