Re: Master Cylinders: Bench Bleed or just mount and bleed ?
[Re: manymopars]
#2202714
11/26/16 01:07 AM
11/26/16 01:07 AM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
I have always mounted the master cylinder in a vise and used an old pushrod to bench bleed the master which also can be accomplished by one person.The master can be bled on the car but now becomes a two person job.If you were working on a GM master cylinder which can be mounted on a severe angle the bench bleeding option is all you have. I've done it both ways however when using DOT 3 and above I've found the actual bench bleeding works the best.
[Re: dvw]
#2202752
11/26/16 02:59 AM
11/26/16 02:59 AM
RapidRobert
I think either way works OK but for mess containment I like to bleed in a vise then cap the ports with a pair of brass inverted flare plugs from the Edelman cabinet at my parts house then move it over to & install it on the vehicle & bleed the corners if they ain't already bled out & if they are I wrap a towel around the lines under the MC & have a helper JUST push it till there is fluid at the brass cones in the MC ports then at that point connect the lines & hopefully nary a single bubble left at those two port/line junction(s). I put a block of wood under the pedal to limit the travel to the normal range & to give the helper a firm stopping point as I coordinate opening/closing the bleeders with his manning the pedal. If discs I like to have him pump vigorously for several strokes then I open a bleeder as he is on the 4th downstroke (perfect verbal timimg needed) as discs can be hard to bleed out & agitating the fluid helps greatly & on a toughie even removing the caliper & blocking the pistons & tilting it in my hand as he works the pedal. the bleeder dont always have to be at 12 0'clock but where the passage meets the caliper bore it must be & some times it ain't & the agitation helps overcome that
[Re: Kern Dog]
#2202760
11/26/16 03:09 AM
11/26/16 03:09 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I have two steel lines that fit the outlets, bend them around to dump into the reservoir. Install M/C, put on bleed lines, put in fluid, slowly work pedal to "bench bleed", remove bleed lines one at a time, installing regular brakes lines and wheel bleed from there.
[Re: Supercuda]
#2202787
11/26/16 11:00 AM
11/26/16 11:00 AM
Posts: 4,283 Florida
blewbyu
I have two steel lines that fit the outlets, bend them around to dump into the reservoir. Install M/C, put on bleed lines, put in fluid, slowly work pedal to "bench bleed", remove bleed lines one at a time, installing regular brakes lines and wheel bleed from there. This is what I do and it works great every time.
[Re: 70Duster]
#2202847
11/26/16 02:40 PM
11/26/16 02:40 PM
Posts: 1,841 South Bend
John Brown
South Bend
I think it's easier and quicker to mount and bleed and skip the bench bleeding step. I use an old baking pan underneath the master cylinder to catch any brake fluid and to keep the mess to a minimum. After bleeding the air out of the master cylinder I attach both lines. Then crack one open slightly and use the line as a bleeder. Then do the same with the other line. Most times the system is then fully bled and I don't even need to bleed again at the wheel cylinders. The last master cylinder change I did on an early Dakota took no more than 15 minutes using this method. Pedal is hard as a rock. You don't use a vise ?? That just sounds like hypocrisy to me. Actually, I never understood why someone would want to bleed their master cyl in a vise on a bench and then take that leaky dripping thing over to the car and try to bolt it on, all while trying to prevent brake fluid from getting on the paint. I was always too lazy to do it the hard way too, so I always mounted mine on the car and went ahead and bled it the way you described above. On cars that have a master that is tilted, I just jacked the rear of the car up. Being lazy can contribute to working smarter instead of harder I always say.
[Re: Kern Dog]
#2203219
11/27/16 10:18 AM
11/27/16 10:18 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If Rick e failed to mention the reasoning behind the skipping the bench bleeding then you do not need to follow that advice.
One thought on bench bleed is you can confirm a full stroke on the bench. On the car you can not ensure that the piston is fully releasing and reaching the bottom.
Bleed lines submerged back into the reservoir then extra steps to catch the dripping fluid during install. Followed by a 4 wheel bleed is the one garanteed method.
[Re: Magnum]
#2203224
11/27/16 10:57 AM
11/27/16 10:57 AM
John Brown
South Bend
Not all m.c.'s are machined for the piston and seal to be pushed farther down the bore than they normally are when bolted onto the car. I have read tech bulletins warning of possible damage to seals when over stroking a master cyl. Down sides do exist in either situation.
[Re: Magnum]
#2203395
11/27/16 05:23 PM
11/27/16 05:23 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Bleed lines submerged back into the reservoir then extra steps to catch the dripping fluid during install. Followed by a 4 wheel bleed is the one garanteed method. If this was just a straight MC to another MC swap, I could see just doing a bench bleed and go. I have had the strange luck where the steel brake lines had fluid all the way to the threads and connecting the new MC requires almost NO bleeding to feel right. This time I am changing to a different NON power setup. The steel lines from the MC to the distribution block need to be shorter and mine look a bit ugly too.
[Re: Kern Dog]
#2203701
11/28/16 01:33 AM
11/28/16 01:33 AM
Posts: 4,588 St. John's Newfoundland
440newport
What reason did GM have for those crazy tilted booster/master cylinder positions??? I had 2 Camaros that were like that and i never knew anyone that knew the reason. I think it had to do with getting the pedal ratio right. If you look at a manual brake GM car, the master cylinder is pretty much level. The power brake ones are tilted to get the back of the mc lower, so that the pushrod is lower on the brake pedal.
