Re: any issues putting a 360 magnum in to a 74 e body?
[Re: 05dakota]
#2211416
12/10/16 07:52 PM
12/10/16 07:52 PM
Posts: 17,861 albany ny
05dakota
albany ny
still cant find that m1 intake
5549 post on old board
[Re: 05dakota]
#2211503
12/10/16 09:42 PM
12/10/16 09:42 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I have a M1 that I'd sell if I get an Edelbrock for mine. Also to correct myself, 340 E/manifolds do fit on the Magnum heads as well as the 340 valve covers. I'm also looking for some of the black cast MP 10 bolt Magnum valve covers.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 05dakota]
#2211924
12/11/16 05:11 PM
12/11/16 05:11 PM
05dakota
albany ny
Cana pro former intake manifold be drilled to fit magnum heads??n
[Re: moparmarks]
#2212081
12/11/16 09:16 PM
12/11/16 09:16 PM
RapidRobert
Never tried it but I read once where a guy drilled down vertical into the LA intake then used spacers under the bolt head with an angle on the lower side of the spacer to match the angle on the LA intake. If I did not have a Mag intake I would try it
[Re: 05dakota]
#2212133
12/11/16 09:59 PM
12/11/16 09:59 PM
Posts: 8,483 Candler,NC / Myrtle Beach, SC
JDMopar
Ted, Edelbrock makes a Performer RPM Airgap for Magnum motors. Summit sells a Chinese knockoff called a Crosswind. A long time ago, a Moparts member had a jig to redrill Magnum heads to fit an LA intake. If I remember right, it disappeared and has never been seen again. Check on Rock Auto for a 5.9 flex plate. The harmonic balancer and the flex plate have to match on Magnum motors. As for Magnum exhaust manifolds, there are different versions. The most common have 1 7/8 exits, and the better ones have larger openings. 2 1/4, I think?
[Re: JDMopar]
#2212146
12/11/16 10:11 PM
12/11/16 10:11 PM
RapidRobert
I was one of the ones who rented the "jig" when it was in circulation. I think a person could mockup the LA intake on the longblock then make a centerpunch mark down the LA intake manifold holes onto the head deck surface then remove the intake/heads & drill/tap the heads in that location(s) which was what the jig did. If the area on the heads you would be drilling into was solid it would work fine (with the jig it was borderline)
